> Fuel pump just quit
surfdogskier
post Oct 26 2019, 11:51 AM
So I had everything working well on my carb conversion with the exception of the fuel pump which constantly ran unless I pulled the ground wire per SirAndys carb conversion write up.
Now my pump will not work at all. I direct wired it to the battery to see if the pump was good and it worked. I connected a 12 volt wire to my relay board at the black/red wire #13 connection and it worked. So no issue with the wire. However something on the relay board or relay prevents it from working when the key is turned on.
I was going to wire it to the 2 other points on the relay board to get 12 volts (T4b and the #12 pin on the T12 connector). However, with the key turned on, I am not getting 12 volts to either of these. the T4b, I am getting 2 volts and the pin 12 on the T12 I am getting 4 volts.
My only other option to get 12 volt power is to connect to my coil but I have read this is not a good idea.
Looking for some guidance.
surfdogskier
post Oct 26 2019, 04:00 PM
I swapped the relays around but there was no difference. I do have power getting to the relay plate but not working at specific locations it should be after that. I located 2 pins on the T14 connector that work when the key is on and turn off when the key is off. I think one is to the starter or alternator light plug based based on the 73 relay board picture LieroFox posted above. I am going to direct wire to that lead and see how that goes and post back.
surfdogskier   Fuel pump just quit   Oct 26 2019, 11:51 AM
rhodyguy   With the key in the on position, do you have 12v a...   Oct 26 2019, 12:03 PM
surfdogskier   With the key in the on position, do you have 12v ...   Oct 26 2019, 12:31 PM
lierofox   So I had everything working well on my carb conve...   Oct 26 2019, 12:32 PM
surfdogskier   So I had everything working well on my carb conv...   Oct 26 2019, 12:33 PM
surfdogskier   I am not seeing any blown fuses under the dash or ...   Oct 26 2019, 12:44 PM
rhodyguy   the last sentence has me confused. The stand alone...   Oct 26 2019, 12:57 PM
surfdogskier   the last sentence has me confused. The stand alon...   Oct 26 2019, 01:03 PM
lierofox   [quote name='rhodyguy' post='2757415' date='Oct 2...   Oct 26 2019, 02:33 PM
surfdogskier   [quote name='rhodyguy' post='2757415' date='Oct ...   Oct 26 2019, 04:57 PM
lierofox   Thanks for this image and info. I haven't se...   Oct 26 2019, 05:18 PM
Minerva's 914   RE: Fuel pump just quit   Oct 26 2019, 01:11 PM
Superhawk996   :rotfl: Well done!   Oct 26 2019, 04:17 PM
rhodyguy   with the extra wire for power and the jumper groun...   Oct 26 2019, 01:46 PM
surfdogskier   with the extra wire for power and the jumper grou...   Oct 26 2019, 02:14 PM
porschetub   Did you check the pump and power supply relays,rea...   Oct 26 2019, 03:22 PM
rhodyguy   Are you sure the relay is good? Plug it in to a re...   Oct 26 2019, 03:26 PM
injunmort   I would suggest getting rid all jumpers, grounds a...   Oct 26 2019, 03:36 PM
surfdogskier   I swapped the relays around but there was no diffe...   Oct 26 2019, 04:00 PM
lierofox   I swapped the relays around but there was no diff...   Oct 26 2019, 04:38 PM
porschetub   I swapped the relays around but there was no dif...   Oct 26 2019, 11:40 PM
surfdogskier   She now purrs like a kitten. Thank all of you fo...   Oct 27 2019, 06:07 AM
KELTY360   She now purrs like a kitten. Thank all of you f...   Oct 27 2019, 02:34 PM
surfdogskier   She now purrs like a kitten. Thank all of you ...   Oct 27 2019, 06:42 PM
lierofox   The biggest point of caution I'd give for that...   Oct 28 2019, 01:17 PM
surfdogskier   The biggest point of caution I'd give for tha...   Oct 28 2019, 01:55 PM
914_teener   :thumbsup: :brain: :blowup:   Oct 28 2019, 01:46 PM
rhodyguy   :blink:   Oct 28 2019, 01:55 PM
Rand   I understand the hack to get by. I do that too. Bu...   Oct 28 2019, 04:09 PM
lierofox   I understand the hack to get by. I do that too. B...   Oct 28 2019, 06:30 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 06:14 PM
