brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
Hello, mechanics and to all. I have an oil leak, seems to be dripping from the strainer. I tightened it good after taking it out and checking to see if there was a gasket, there was one. It is very flat, do I need to buy a new gasket? Maybe it is from a different source just looking like it's from the oil strainer ????????????????
mankowski |
Member ![]() ![]() Group: Members Posts: 128 Joined: 7-February 10 From: Portland, Oregon Member No.: 11,335 Region Association: Pacific Northwest ![]() |
The retaining bolt for the oil screen cover has a very low torque — 9.4 foot pounds. Over tightening can cause a leak and damage to the baffle plate or case. If you’re not sure where the leak is from — there or higher up for example the oil cooler seals, dry everything off and then restart the engine so that you can see where the leak originates.
Lo-Fi Version | Time is now: 27th June 2024 - 06:34 PM |
