Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
With the rash of shifting issues popping up doing a GB so you can inexpensively replace all the bushings in one shot even the cover and correct band to keep the crud out.
You will get the 1 cup bushing ( one at the transmission) the bushing at the firewall the knuckle bushing (yes set of 2) the transmission guide bushing the rubber sleeve for the rod at the transmission Option for new cover ... at $8 option for new cover band and hardware at $9 Maybe even a few other options (IMG:style_emoticons/default/biggrin.gif) You know me ..while you are there. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
I'm in. Adding new cone screws sounds like it would be a good option!
Lo-Fi Version | Time is now: 30th June 2024 - 08:12 PM |
