crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
So blew up my #3 rod. wondering what caused this. lack of oil, due to rpm? poor return? oil pump sucking air?
last time it was #2 rod. I really don't want to live with this again. Motor specs, Dual oil coolers with full flow plumbing 102 bore by 80mm stroke long rods, ham heads and valve train. Running to 6800 rpm g loads to 1.5 windage tray modified at pushrod tubes for oil flow tuna can with 1/2 extra oil Pics of horror below. First are this failure, then old failure. ![]() ![]() ![]() ![]() |
crash914 |
I will know more after the post. Engine is ready to drop. I should have it apart Saturday. Small thin bearing material in the sump. Correct on 1 sheared rod bolt. The other is ok, I haven't found the rod cap yet
Lo-Fi Version | Time is now: 26th June 2024 - 09:05 AM |
