crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
So blew up my #3 rod. wondering what caused this. lack of oil, due to rpm? poor return? oil pump sucking air?
last time it was #2 rod. I really don't want to live with this again. Motor specs, Dual oil coolers with full flow plumbing 102 bore by 80mm stroke long rods, ham heads and valve train. Running to 6800 rpm g loads to 1.5 windage tray modified at pushrod tubes for oil flow tuna can with 1/2 extra oil Pics of horror below. First are this failure, then old failure. ![]() ![]() ![]() ![]() |
crash914 |
I did get some warning (that I ignored) running hotter than normal, low oil pressure at idle, knock, etc.
I heard something happen part way through a run. but nothing visible outside. I knew better than to run it, but only 2 runs to finish the season....No detonation, running 100+ octane at 12:1 afr. this was a really fast motor. revved quick and put the power down. I figure close to 200hp and also 180ish torque. |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
I did get some warning (that I ignored) running hotter than normal, low oil pressure at idle, knock, etc. I heard something happen part way through a run. but nothing visible outside. I knew better than to run it, but only 2 runs to finish the season....No detonation, running 100+ octane at 12:1 afr. this was a really fast motor. revved quick and put the power down. I figure close to 200hp and also 180ish torque. Herb, you can't assume that because you have a fat AFR that you aren't experiencing detonation. Indeed, because a fat tune takes extra time to react completely in the combustion chamber it's common to have elevated temps around the exhaust valve and higher egt's since the fuel burned at the end of the cycle does so around the valve. That concentrated heat can definitely contribute to detonation. You said it was running hotter than normal. CHT's, EGT"S, oil. . . what was running hotter? You may need an accusump. Your rod failures might be a combo of state of tune and inadequate oiling. Could just be oiling alone. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:11 AM |
