crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
So blew up my #3 rod. wondering what caused this. lack of oil, due to rpm? poor return? oil pump sucking air?
last time it was #2 rod. I really don't want to live with this again. Motor specs, Dual oil coolers with full flow plumbing 102 bore by 80mm stroke long rods, ham heads and valve train. Running to 6800 rpm g loads to 1.5 windage tray modified at pushrod tubes for oil flow tuna can with 1/2 extra oil Pics of horror below. First are this failure, then old failure. ![]() ![]() ![]() ![]() |
crash914 |
Good read. Thanks Len.
For things to note, I did see my dip stick extend after runs. Seems to indicate excessive crank case pressure. I did have the heads vented to a breather box that drains back. The dry sump and no vents sounds promising. |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Good read. Thanks Len. For things to note, I did see my dip stick extend after runs. Seems to indicate excessive crank case pressure. I did have the heads vented to a breather box that drains back. The dry sump and no vents sounds promising. Herb, if you're just AXing then a dry sump system would probably be overkill. A lot goes into converting a wet-sump engine into a properly designed dry sump engine. Keep the tuna can. Dump the head vents and add an Accusump. As for the possibility of detonation, one easy tell-tale sign you can look for during disassembly is if top and second ring gaps have lined up. That's a classic sign of detonation. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:14 AM |
