seat out.....take relays out ?, 1974 914 1.8 |
brcacti |
Nov 2 2019, 03:52 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
FlacaProductions |
Nov 6 2019, 11:45 AM
Senior Member Group: Members Posts: 1,648 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
put the yellow wires back and see if it cranks.
brcacti |
Nov 6 2019, 02:53 PM
put the yellow wires back and see if it cranks. Hello, yes I put new connections on the two yellow wires and plugged them back into where they were before, won't crank. From the add on starter relay I get a reading of 12.47 from the big black to the yellow and same reading from the big black to the white. NO READING from the big black to the 1/4 inch nut connection that I used to jump start this way, now nothing. Did I burn out my add on starter relay? |
brcacti |
Nov 6 2019, 03:19 PM
put the yellow wires back and see if it cranks. Hello, yes I put new connections on the two yellow wires and plugged them back into where they were before, won't crank. From the add on starter relay I get a reading of 12.47 from the big black to the yellow and same reading from the big black to the white. NO READING from the big black to the 1/4 inch nut connection that I used to jump start this way, now nothing. Did I burn out my add on starter relay? FORGET this post, in all my inexperience and haste I forgot to plug one wire from the add on starter relay into the starter, I CAN JUMP START IT NOW AGAIN (IMG:style_emoticons/default/smile.gif), the relay is not bad. It still does not start from the key, may be a bad ignition switch, will try another test |
Lo-Fi Version | Time is now: 27th June 2024 - 06:47 AM |
