> Trying to start my carbureted 1.7, Electrical help
pastormacman
post Nov 11 2019, 11:21 AM
Issue: There's no power going to the coil/fuel pump when I turn the key. (you can skip the history and jump down to the ALL CAPS and (IMG:style_emoticons/default/popcorn[1].gif) to see more about the issue)
History: 16 years ago, this was a running 1.7 fuel injected '73 in Bakersfield, CA. I bought it wrecked in the front end, (hood crunched a little, passenger fender dented) A friend straightened the trunk, cut off and welded a replacement fender on and we put on a replacement hood. I had it painted and new tires on it. It was my daily driver for a couple of years.
14 years ago, I got a new daily driver and this sat for a few months. Unbeknownst to me, a critter made it's home around one of the cylinders with mud and leaves. I went to drive it and the cylinder overheated and seized the engine. I bought new cylinders and took it to a friend to replace. Upon removing the engine he discovered that my block was cracked. I found a rebuilt 1.7 down in Los Angeles and bought it to replace the old engine. My mechanic friend was going to work on it in his spare time for me.
I had always had trouble with the fuel injection, so I saw this as an opportunity to remove it and replace it with carbs. So he installed the carbs and after he got the engine back in the car, he discovered his dog had eaten the wiring harness (From the relay plate to the alternator/starter) At that point, life happened... kids grew up, I worked a lot and the car sat in that condition in one of the bays in his shop for 10 years.
Three years ago, my sons are now teenagers, and I decided I wanted to finish it up and get it out of my friends way. He had kind grown resentful of it being there. I brought it home and put it on jack stands in my garage. I ordered a new wiring harness and tried to finish the car to get it started for my kids to drive. I discovered that through life I had developed a strong case of claustrophobia and it's difficult to get under the car for me. So it has sat for another three years.
So I have a new friend who rebuilds VW Bugs who is now helping me.We've gotten all the electrical hooked back up. Removed the gas tank and flushed it out. replaced all the fuel lines, and filters. And got a new battery. Which brings me to the present...
(IMG:style_emoticons/default/popcorn[1].gif) ISSUE: WHEN WE TURN THE KEY, THERE'S NO POWER TO THE COIL OR FUEL PUMP.
Since we replaced the fuel injection with carburetors, we no longer have the ECU in the car. (in fact, I no longer have the ECU or any of the fuel injection parts anymore, they are long gone at my other friends garage) Not sure if that was a mistake, I thought I didn't need it anymore since the FI was gone.
My VW friend is not familiar enough with 914 electrical to find the issue. Could I have a bad relay? I see that there is a port for the white wires from the ECU to connect to the relay panel. Is there a part I need there in place of the ECU wiring? Is this a common issue with a carb replacement? Other electrical things work, (headlights, and whatnot) and if I continue to turn the key, the starter starts to crank, but no power to the coil/fuel pump.
Any help would be appreciated. Sorry for the long post.
TheCabinetmaker
post Nov 11 2019, 12:56 PM
I drive my car everyday
Since you don't have the injection system on it anymore, you will have to find a source of switched power. You cannot use the fuel injection pump. Way too much pressure.
pastormacman
post Nov 11 2019, 01:36 PM
QUOTE(TheCabinetmaker @ Nov 11 2019, 10:56 AM) *
Since you don't have the injection system on it anymore, you will have to find a source of switched power...
I just saw that this was not referring to the fuel pump. What do you mean a source of switched power?
pastormacman   Trying to start my carbureted 1.7   Nov 11 2019, 11:21 AM
porschetub   Issue: There's no power going to the coil/fue...   Nov 11 2019, 12:51 PM
pastormacman   Wow some history right there,by all means check th...   Nov 11 2019, 01:34 PM
TheCabinetmaker   Since you don't have the injection system on i...   Nov 11 2019, 12:56 PM
pastormacman   Since you don't have the injection system on ...   Nov 11 2019, 01:21 PM
pastormacman   Since you don't have the injection system on ...   Nov 11 2019, 01:36 PM
pastormacman   Just looked at ordering a low pressure fuel pump a...   Nov 11 2019, 01:55 PM
Spoke   If you didn't ground pin III on the FI ECU con...   Nov 11 2019, 02:14 PM
ndfrigi   http://www.914world.com/bbs2/index.php?sho...41299...   Nov 11 2019, 02:16 PM
porschetub   http://www.914world.com/bbs2/index.php?sho...4129...   Nov 11 2019, 04:02 PM
DickSteinkamp   If you are unsure if your fuel pump is a low press...   Nov 11 2019, 02:20 PM
SirAndy   http://www.914world.com/specs/SirAndyCarbFuelPumpR...   Nov 11 2019, 05:07 PM
pastormacman   That link to SirAndy's instructions was very h...   Nov 11 2019, 05:24 PM
SirAndy   I'm also starting to realize that maybe my fue...   Nov 11 2019, 05:27 PM
pastormacman   I used the CB rotary pump below on my carbed 2056 ...   Nov 11 2019, 06:04 PM
surfdogskier   [quote name='SirAndy' post='2761314' date='Nov 11...   Nov 11 2019, 06:08 PM
surfdogskier   That link to SirAndy's instructions was very ...   Nov 11 2019, 06:00 PM
surfdogskier   I just found this which I saved on my computer. L...   Nov 11 2019, 06:05 PM
rhodyguy   More likely than not, that facet pump pressure is ...   Nov 11 2019, 06:07 PM
rhodyguy   Is the pump connected to the original wires?   Nov 11 2019, 07:53 PM
pastormacman   Is the pump connected to the original wires? Not...   Nov 12 2019, 08:21 AM
jcd914   Is the pump connected to the original wires? No...   Nov 12 2019, 10:01 AM
pastormacman   Your test light won't pass enough current to r...   Nov 12 2019, 10:25 AM
rhodyguy   The plug end of the stock pump harness will have d...   Nov 12 2019, 10:58 AM
pastormacman   Is the facet mounted to the bottom of the engine s...   Nov 12 2019, 02:13 PM
ndfrigi   Is the facet mounted to the bottom of the engine ...   Nov 12 2019, 02:19 PM
pastormacman   Is the circled one you are referring too? that is ...   Nov 12 2019, 02:45 PM
ndfrigi   Is the circled one you are referring too? that is...   Nov 12 2019, 03:25 PM
pastormacman   Ok. Been busy with work but was able to work on th...   Dec 7 2019, 02:58 PM
pastormacman   So I decided to test the connection by pushing a p...   Dec 7 2019, 03:16 PM
rhodyguy   The 2 fuses on the relay board are filthy. Clean t...   Dec 7 2019, 04:13 PM
pastormacman   Are there any fuses or relays under the dash that ...   Dec 7 2019, 11:43 PM
porschetub   No none to worry about in that area,have you check...   Dec 8 2019, 01:33 PM
SirAndy   Did you check the fuel pump relay? Your relay boar...   Dec 8 2019, 02:28 PM
Spoke   You can test the relays involved with providing th...   Dec 8 2019, 10:23 PM
IronHillRestorations   Make sure the fuel hose isn't kinked, it's...   Dec 9 2019, 06:51 AM
pastormacman   Make sure the fuel hose isn't kinked, it...   Dec 14 2019, 12:30 PM
Tom   In your original post you said you had no power to...   Dec 9 2019, 08:46 PM
pastormacman   OK. I retested all the relays I have on the headli...   Dec 14 2019, 12:11 PM
Spoke   There is no power on either side of fuse #9 under...   Dec 14 2019, 12:58 PM
pastormacman   With the key OFF, there is no power to the fuses f...   Dec 14 2019, 01:35 PM
Spoke   With the key OFF, there is no power to the fuses ...   Dec 14 2019, 06:39 PM
pastormacman   OK, so here's my update for today. I can...   Dec 15 2019, 09:01 PM
Spoke   Those numbers go to somewhere else on the schemati...   Dec 16 2019, 08:43 AM
Spoke   Fuse 8 is powered by pin X on the ignition switch ...   Dec 16 2019, 08:56 AM
pastormacman   Fuse 8 is powered by pin X on the ignition switch...   Dec 16 2019, 06:50 PM
Tom   Pastormacman, It looks like you are using the ...   Dec 16 2019, 10:20 AM
pastormacman   Pastormacman, It looks like you are using the...   Dec 16 2019, 06:07 PM
Tom   More   Dec 16 2019, 10:21 AM
pastormacman   THANK YOU! I want to thank everyone who helpe...   Jan 2 2020, 03:53 PM
pastormacman   THE FACE I MADE WHEN MY CAR STARTED! After...   Mar 23 2020, 10:26 AM
- Lo-Fi Version Time is now: 26th April 2025 - 02:40 AM
