pastormacman |
Newbie ![]() Group: Members Posts: 28 Joined: 6-July 05 From: Bakersfield, CA Member No.: 4,382 ![]() |
Issue: There's no power going to the coil/fuel pump when I turn the key. (you can skip the history and jump down to the ALL CAPS and (IMG:style_emoticons/default/popcorn[1].gif) to see more about the issue)
History: 16 years ago, this was a running 1.7 fuel injected '73 in Bakersfield, CA. I bought it wrecked in the front end, (hood crunched a little, passenger fender dented) A friend straightened the trunk, cut off and welded a replacement fender on and we put on a replacement hood. I had it painted and new tires on it. It was my daily driver for a couple of years. 14 years ago, I got a new daily driver and this sat for a few months. Unbeknownst to me, a critter made it's home around one of the cylinders with mud and leaves. I went to drive it and the cylinder overheated and seized the engine. I bought new cylinders and took it to a friend to replace. Upon removing the engine he discovered that my block was cracked. I found a rebuilt 1.7 down in Los Angeles and bought it to replace the old engine. My mechanic friend was going to work on it in his spare time for me. I had always had trouble with the fuel injection, so I saw this as an opportunity to remove it and replace it with carbs. So he installed the carbs and after he got the engine back in the car, he discovered his dog had eaten the wiring harness (From the relay plate to the alternator/starter) At that point, life happened... kids grew up, I worked a lot and the car sat in that condition in one of the bays in his shop for 10 years. Three years ago, my sons are now teenagers, and I decided I wanted to finish it up and get it out of my friends way. He had kind grown resentful of it being there. I brought it home and put it on jack stands in my garage. I ordered a new wiring harness and tried to finish the car to get it started for my kids to drive. I discovered that through life I had developed a strong case of claustrophobia and it's difficult to get under the car for me. So it has sat for another three years. So I have a new friend who rebuilds VW Bugs who is now helping me.We've gotten all the electrical hooked back up. Removed the gas tank and flushed it out. replaced all the fuel lines, and filters. And got a new battery. Which brings me to the present... (IMG:style_emoticons/default/popcorn[1].gif) ISSUE: WHEN WE TURN THE KEY, THERE'S NO POWER TO THE COIL OR FUEL PUMP. Since we replaced the fuel injection with carburetors, we no longer have the ECU in the car. (in fact, I no longer have the ECU or any of the fuel injection parts anymore, they are long gone at my other friends garage) Not sure if that was a mistake, I thought I didn't need it anymore since the FI was gone. My VW friend is not familiar enough with 914 electrical to find the issue. Could I have a bad relay? I see that there is a port for the white wires from the ECU to connect to the relay panel. Is there a part I need there in place of the ECU wiring? Is this a common issue with a carb replacement? Other electrical things work, (headlights, and whatnot) and if I continue to turn the key, the starter starts to crank, but no power to the coil/fuel pump. Any help would be appreciated. Sorry for the long post. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,238 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
The plug end of the stock pump harness will have dif connectors. Make up a pig tail that works with the replacement pump. The relay board trick and start tracking circuits. Remove the coil from equation.
Is the facet mounted to the bottom of the engine shelve? Is that a J tube hole above it? |
pastormacman |
Is the facet mounted to the bottom of the engine shelve? Is that a J tube hole above it? Yes it's mounted to the bottom underside of the "hell hole" I'm not sure what the J tube is. Is it the tube to drain the water from the engine lid? I think that might be it. My drainage tubes all disintegrated over time and are no longer there. |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,965 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Is the facet mounted to the bottom of the engine shelve? Is that a J tube hole above it? Yes it's mounted to the bottom underside of the "hell hole" I'm not sure what the J tube is. Is it the tube to drain the water from the engine lid? I think that might be it. My drainage tubes all disintegrated over time and are no longer there. Is the circled one you are referring too? that is the hole where the fuel pump wire coming from and should have a rubber gromet. ![]() |
pastormacman |
Is the circled one you are referring too? that is the hole where the fuel pump wire coming from and should have a rubber gromet. I assumed that was the hole you were referring to. I'm not home right now so I can't take a look at it to confirm. By my memory I assumed it was the drainage hole, but it probably is the access hole for the Fuel pump wiring. The connector and the rubber grommet are no longer on the wiring. The wiring is currently still up in the engine bay cut bare. I will eventually run them back down the access hole and crimp them to the red and black wires coming off the fuel pump, so that it's all running through the original wiring loom. |
Lo-Fi Version | Time is now: 26th April 2025 - 02:57 AM |
