> Anyone disassembled/restored seat belt receivers
doug_b_928
post Nov 15 2019, 11:35 AM
I did a search but didn't see any posts showing the disassembly/reassembly/restoration of the female seat belt receivers. Mine are pictured below. I've ordered new stickers but would like to replate the screws on the back and the main steel portion (mine were very corroded where they bolt into the car; I put POR15 on them a couple of years ago but I'd rather disassemble, media blast and replate the whole thing). Any advice based on past experience with disassembly/reassembly would be much appreciated (as always).
FlacaProductions
post Nov 15 2019, 04:38 PM
I know the OP is talking about the receivers but there has been mention of the retracting part as well.
I took two of them somewhat apart recently - but I did NOT take the cover (the thinner of the two) that houses the coil spring off.
Instead, I fully extended the belt and then pushed the webbing back thru the metal bar where it is held by another bar that runs through a pocket in the belt. Slide the bar out but be mindful that the bar will spin (quickly) if released.
I put a screwdriver in the slot that kept the retractor in this position while I put the belt in a bucket of Woolite-water and washed 'em out and hung them out to dry.
While they were drying, I took the screwdriver through the slot and advanced the rod to the point where it wouldn't go any more and then backed off a half-turn. It did seem to add significantly to the amount of tension in the retraction action.
I did add a small amount of silicone lube to where the bar spins and then put the belt back through the slot, securing it with the pin. It retracted quite well and I'll be putting them back in the car in a couple of weeks. I'll report back....probably in a separate thread.
doug_b_928   Anyone disassembled/restored seat belt receivers   Nov 15 2019, 11:35 AM
ConeDodger   Try including as the person who posted “PRS914-6...   Nov 15 2019, 11:46 AM
johnhora   Just remove the 4 small screws you see on the back...   Nov 15 2019, 01:15 PM
914Sixer   I have never taken one apart.   Nov 15 2019, 01:16 PM
johnhora   Mark.. It's really not too bad of disassembly ...   Nov 15 2019, 03:05 PM
doug_b_928   Thanks, guys. I took one apart and per Jonhora th...   Nov 15 2019, 04:24 PM
FlacaProductions   I know the OP is talking about the receivers but t...   Nov 15 2019, 04:38 PM
Mikey914   I do have you covered on the PRESS stickers https:...   Nov 15 2019, 07:04 PM
doug_b_928   @Mikey914 Mark, I didn't know that you carry...   Nov 16 2019, 01:36 PM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 16 2019, 01:42 PM
Mikey914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Nov 16 2019, 05:31 PM
worn   Yeah, but the Ss look pretty good.   Nov 16 2019, 07:16 PM
KELTY360   Yeah, but the Ss look pretty good. No, the ‘S...   Dec 8 2019, 12:41 PM
burton73   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 8 2019, 02:53 PM
KELTY360   [quote name='bbrock' post='2762574' date='Nov 16 ...   Dec 8 2019, 03:34 PM
doug_b_928   I'm Canadian but I'll plead the 5th anyway...   Nov 16 2019, 01:44 PM
bahnzai   Oh man! This little exchange made me laugh my ...   Nov 16 2019, 04:07 PM
doug_b_928   I finally had some time to complete the restoratio...   Dec 7 2019, 10:27 PM
90quattrocoupe   ^^^^Nice.   Dec 7 2019, 10:34 PM
Jett   I finally had some time to complete the restorati...   Dec 8 2019, 10:26 AM
FlacaProductions   I'm re-installing my retractors today and I...   Dec 8 2019, 08:46 AM
doug_b_928   @90quattrocoupe Thanks, I'm really happy wit...   Dec 8 2019, 10:18 AM
Jett   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 8 2019, 10:24 AM
doug_b_928   Thanks. Brent Brock taught me about DigiKey for e...   Dec 8 2019, 10:32 AM
Jett   Thanks. Brent Brock taught me about DigiKey for ...   Dec 8 2019, 10:51 AM
bbrock   Nice work Doug :trophy: Thanks for the tip on the ...   Dec 8 2019, 02:45 PM
doug_b_928   Thanks, Brent. I should add that I also washed wi...   Dec 8 2019, 05:27 PM
Rob-O   How did you replate the section that bolts to the ...   Dec 8 2019, 07:24 PM
doug_b_928   How did you replate the section that bolts to the...   Dec 8 2019, 10:33 PM
FlacaProductions   @doug_b_928 and [b]@[url=http://www.914world.com...   Dec 8 2019, 08:15 PM
914_7T3   Great call on the suggestion of Krylon plastic pai...   Mar 29 2020, 06:36 PM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th November 2024 - 08:35 AM
