Why not use bushing grease on a-arm bushings? |
Tdskip |
Nov 16 2019, 01:01 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - I know how it is commonly done including Ian’s great video. Is there a reason why not to use bushing grease instead of softsoap?
So you want the bushing NOT to move or rotate ones installed? I assume that is a reason but wanted to ask. Thanks. |
bbrock |
Nov 17 2019, 09:37 AM
The press fit of the original rubber bushings is so tight that I think those bushings are intended to act as rubber springs rather than a bearings.
The factory manual calls for "glycerine paste" on sway bar bushings. I substituted silicone grease since glycerine paste seems be a thing of the past. |
Tdskip |
Nov 17 2019, 10:43 AM
The press fit of the original rubber bushings is so tight that I think those bushings are intended to act as rubber springs rather than a bearings. The factory manual calls for "glycerine paste" on sway bar bushings. I substituted silicone grease since glycerine paste seems be a thing of the past. Good morning and thanks all. @bbrock - bingo, exactly what I was wondering. Doing mental gymnastics on if easier motion helps ride and handling or would make it sloppy and under damped. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:33 PM |
