Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Hi guys - I know how it is commonly done including Ian’s great video. Is there a reason why not to use bushing grease instead of softsoap?
So you want the bushing NOT to move or rotate ones installed? I assume that is a reason but wanted to ask. Thanks. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The OEM are intended to set a zero preload on the arm. At neutral they have a minimal load. As they are deflected they help to provide a load to return to neutral. The Elephant video was showing the URO spinning in the mount. Effectively providing no load to bring back to neutral.
If this was the intended design it would have been made with a bearings. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:11 PM |
