factory oil temp gauge range |
jmitro |
Nov 18 2019, 07:39 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
at what temperature F should the factory 60mm temp gauge start registering?
Using a thermometer, I inserted the factory 200 degree temp sender into boiling water, but the temp gauge did not rise. I know it has power and is grounded because the needle moves when power is applied, but the gauge otherwise does not rise. at 200 degrees F, should the factory gauge show movement? |
jcd914 |
Nov 18 2019, 10:26 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Did you have a good ground connection to the temp sensor?
I have had some trouble in the past grounding sensors while heating them up to test them. I usually use a chunk of copper household wire and twist it around the sensor threads and then clip my test lead to the copper wire.. Jim |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:28 PM |
