Cone Screw install, Does this look right |
Coondog |
Nov 18 2019, 07:24 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
GregAmy |
Nov 19 2019, 07:37 AM
Advanced Member Group: Members Posts: 2,385 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Does the Patrick part have a hole in the shaft into which the cone screw inserts? If not, then you're not supposed to use a stock cone screw, you're supposed to use a tapered tip screw (assuming supplied with the part).
If you use a cone screw on a solid shaft it'll fall out right quickly. Edit: just to explain why that is, a cone screw slides snugly into a tapered hole; it works on shear on that cone. A tapered tip screw screws down into the steel shaft and, while it makes a slight indentation on the shaft, works primarily on friction. This is why, if you're tightening down the [strike]tapered[/strike] correction: CONE screw so damned hard that you're stripping out the Allen head, you're doing it wrong. It needs to be snug, and you use blue Loc-Tite to keep the screw from backing out, not hammering it home. |
Lo-Fi Version | Time is now: 28th September 2024 - 03:02 PM |
