Cone Screw install, Does this look right |
Coondog |
Nov 18 2019, 07:24 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
GregAmy |
Nov 19 2019, 07:37 AM
Advanced Member Group: Members Posts: 2,319 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Does the Patrick part have a hole in the shaft into which the cone screw inserts? If not, then you're not supposed to use a stock cone screw, you're supposed to use a tapered tip screw (assuming supplied with the part).
If you use a cone screw on a solid shaft it'll fall out right quickly. Edit: just to explain why that is, a cone screw slides snugly into a tapered hole; it works on shear on that cone. A tapered tip screw screws down into the steel shaft and, while it makes a slight indentation on the shaft, works primarily on friction. This is why, if you're tightening down the [strike]tapered[/strike] correction: CONE screw so damned hard that you're stripping out the Allen head, you're doing it wrong. It needs to be snug, and you use blue Loc-Tite to keep the screw from backing out, not hammering it home. |
Coondog |
Nov 19 2019, 08:48 AM
Does the Patrick part have a hole in the shaft into which the cone screw inserts? If not, then you're not supposed to use a stock cone screw, you're supposed to use a tapered tip screw (assuming supplied with the part). If you use a cone screw on a solid shaft it'll fall out right quickly. Edit: just to explain why that is, a cone screw slides snugly into a tapered hole; it works on shear on that cone. A tapered tip screw screws down into the steel shaft and, while it makes a slight indentation on the shaft, works primarily on friction. This is why, if you're tightening down the tapered screw so damned hard that you're stripping out the Allen head, you're doing it wrong. It needs to be snug, and you use blue Loc-Tite to keep the screw from backing out, not hammering it home. Thanks, I will investigate more on the tapered tip screw, and yes PMS installed it with a cone screw. |
Lo-Fi Version | Time is now: 28th June 2024 - 02:34 PM |
