factory oil temp gauge range |
jmitro |
Nov 18 2019, 07:39 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
at what temperature F should the factory 60mm temp gauge start registering?
Using a thermometer, I inserted the factory 200 degree temp sender into boiling water, but the temp gauge did not rise. I know it has power and is grounded because the needle moves when power is applied, but the gauge otherwise does not rise. at 200 degrees F, should the factory gauge show movement? |
jmitro |
Nov 19 2019, 07:26 AM
no, i didn't ground the temp sender.
maybe that was my problem.... thanks for the tip. I'll give it a try |
VaccaRabite |
Nov 19 2019, 01:05 PM
En Garde! Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:08 PM |
