MaxJax Black Friday promo?, Looking for a deal. Post up car related BF deals here. |
VaccaRabite |
Nov 26 2019, 05:16 PM
En Garde! Group: Admin Posts: 13,636 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I want a MacJax lift for my garage. I want to buy it Friday/Monday.
Who has seen deals for it? If you have seen other killer deals for BF/CM post them up here. Zach |
Mikey914 |
Nov 26 2019, 06:40 PM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I like the idea of putting a lift in. But I can see the specifications for the anchor loads, and I'm wondering if the typical garage floor meets the spec. Looks like they are using 1/2" anchors.
Who has put one in so far, and what was your experience? |
Lucky9146 |
Nov 27 2019, 11:44 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,668 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I like the idea of putting a lift in. But I can see the specifications for the anchor loads, and I'm wondering if the typical garage floor meets the spec. Looks like they are using 1/2" anchors. Who has put one in so far, and what was your experience? I did, I love it, and made my more permanent. I added structural steel to the ceiling as my 33 year old garage floor was not something I was tilling to trust with those 5 anchors. Intended to be portable I came to learn that set up was crucial. Originally I thought I would install it on my side drive, just leaving the anchors in place, and putting the posts up when needed, but reading the instructions they want pretty much nats-ass alignment with all kinds of warnings. So I shelved it until I decided on the permanent install. I chose the single car side of my 3 car garage and although tight, it has worked out very very well. I can honestly say it has been a very useful addition and I use it all the time, because I can! Up in the air Because I wanted to mount it next to the stem wall, I also added wall attachment on that side as the cement pour for the slab was not done with the stem wall. I created an "T" beam sorta out of 2" angle iron welded back to back and then tied those into the ceiling joist. Sorry about the blurry pic. I also took the pump and tank and mounted it to the wall and ditched the cart. With marks on the floor for car placement I can have my 914 up in the air in minutes. Because the posts end up right where the door opens, I just back the car in a little further, get out and roll the car forward into position. Also, all these pics were from the install, I now back in all the time, which in my situation makes the getting in and out much easier. I have had my 911 on the lift as well. Love it! Hope this helps for those considering. |
Lo-Fi Version | Time is now: 14th January 2025 - 06:08 PM |
