 Forum Rules Classified Rules!
> Sold! Signal Orange 1970 914-6, real -6 with steel GT flares, 70' 2.2S MFI engine, Numbers matching car comes with original longblock.
Dominic
post Oct 7 2019, 09:44 PM
Dominic
12/07/2019 UPDATE: SOLD!
11/26/2019 UPDATE: Sale Pending!
10/13/2019 UPDATE: Added more details / info and pictures to the last few posts.
For Sale:
I have decided to sell my 914-6, I have owned the car almost 5 years and have put less than 1000 miles on it in that time. I have come to the realization that I have too many projects / cars and not enough time.
This is an original 6 that was restored several years back with Steel GT flares
Paint: Signal Orange (Original Color)
Engine: 1970 2.2S MFI engine rebuilt by Denny Aker's in Seattle
Exhaust: Stock 914-6 heat exchangers with modified 911 muffler for 2 in / 2 out.
Trans: Side Shift transaxle, stock -4 gear ratios, GT Torque Biasing Diff, J-west side shift linkage update
Brakes: Front: 911S Alloy Calipers, Rears: 914-6 GT mod with drilled / vented rotors on all four corners
Wheels: Fuchs 15x7" Fronts, 15x8" Rears (comes with 15x8" spare)
Interior: Momo Prototipo wheel, GTS classic seats with houndstooth inserts, Nakamichi CD player with removable face and aftermarket speaker pods.
Body / Exterior: Steel fender flares, steel rocker panels modified for flares, steel front valance modified for flares, GT engine lid built by Sergio Meza, Hella Euro lenses front and rear. Re-chromed front and rear original bumpers with license plate holed welded up on front bumper (high quality chrome work, you have to see these to appreciate how nice they are), new / perfect rubber bumper tops. Original side view mirror (drivers side only)
Battery: Odyssey PC680 dry cell battery, rennline battery holder, hella battery cut-off switch, relocated to front trunk (see pics).
Original Numbers matching 2.0L longblock included
COA included with car along with large folder of records.
Asking: $79,000
*Update: 11/12/2019 Lowered price to $75,000.
Serious buyers will have to PM me with an actual phone number, internet scammers can F#ck-off (IMG:style_emoticons/default/mad.gif)
I will add more pics and details in the coming days.
As promised here is a list of items I have replaced since I have owned car.
Work Performed Summer 2015:
Installed new speedometer cable
Installed new J-West side shifter linkage
Install late style parking brake handle
Installed 944 inertia reel seat belts
Installed new Hella Euro front turn signal lenses
Replaced front sway bar drop links with adjustable units
Replaced front suspension bushings
Replace oil pressure sender with new VDO 0-80 psi sender to match gauge
Replace fuel tank sending unit with new VDO part
Rebuilt pedal cluster with new bronze bushings, new clutch shaft and spring.
Replaced right targa bar window seal
Replaced Fuel Filler Cap seal
Replaced old “914-6” emblem with NOS gold 914-6 script
Installed new 12v power adapter under dash (for GPS/phone charger)
Repainted petals all four Fuchs wheels with aluminum paint (RSR look)
Remove muffler, cleaned, re-welded tail pipe, painted with grey ceramic paint
Replaced MFI fuel filter in engine compartment
Installed New Rear adjustable Koni shocks with coil over kit (175 lbs springs)
Work performed Summer of 2018:
Removed engine / Trans / Oil tank / Fuel Tank
Installed New front motor mount
Installed New Engine Comp Rubber Seals
Installed new stainless steel fuel lines through tunnel.
Installed new oil supply line from oil tank to engine.
Adjusted valves, replaced valve cover gaskets with new silicon units (no leaks)
Replaced alternator / alternator belt.
Media blasted 11 blade fan and clear coated fan
Installed new 123 Ignition programmable blue tooth Distributor
Replaced rear brake hosed with new DOT Stainless steel lines.
Cleaned and Tested all MFI injectors, replaced one bad injector
Installed new IMI Hi-Torque Starter
Recent Work Performed:
Replaced alloy lug nuts - Oct 2019
Installed new Odyssey PC680 Battery – Oct 2019
Installed New first / Reverse Slider and 1st gear syncro – Oct 2019
Cairo94507
post Nov 27 2019, 02:13 PM
Michael
Congratulations to Ben and Dominic. (IMG:style_emoticons/default/beerchug.gif)
Dominic   Sold! Signal Orange 1970 914-6, real -6 with steel GT flares, 70' 2.2S MFI engine   Oct 7 2019, 09:44 PM
raynekat   Looks like a great ride there Dominic. GLWTS You ...   Oct 8 2019, 12:22 AM
Bruce Hinds   WOW - If I could afford a 6 that would be the one...   Oct 8 2019, 05:43 AM
Cairo94507   Great looking Six- GLWTS. :beer2:   Oct 8 2019, 07:47 AM
pete000   DON'T SELL IT !!   Oct 8 2019, 10:12 AM
BuddyV   …. original motor … included? :beer2:   Oct 8 2019, 10:44 AM
EdwardBlume   …. original motor … included? :beer2: ...   Oct 9 2019, 07:07 AM
Dominic   More pics of Interior...   Oct 8 2019, 10:32 PM
Mike Fitton   Looks like the Tach and combo gauge are non-origin...   Oct 9 2019, 08:09 AM
Dominic   Looks like the Tach and combo gauge are non-origi...   Oct 9 2019, 09:00 PM
Rufus   This appears to be an awesome 914/6 ... I love it...   Oct 9 2019, 11:02 AM
a9146luvr   If this is a "/car" that you are selling...   Oct 9 2019, 11:30 AM
JOEPROPER   If this is a "/car" that you are sellin...   Oct 9 2019, 11:54 AM
flat4guy   Beautiful car - it's always a timing issue wit...   Oct 9 2019, 08:37 PM
Dominic   More pics.. last one shows the rear trunk panel wi...   Oct 13 2019, 04:22 PM
sixnotfour   I bought it out of a Barn 1998?? 2011 BAT https://...   Oct 29 2019, 11:45 AM
RSWannabe   I just had this ad brought to my attention. I...   Nov 8 2019, 01:48 PM
Dominic   I just had this ad brought to my attention. I...   Nov 8 2019, 07:44 PM
Dominic   Update: 11/12/2019 Lowered price to $75,000.   Nov 12 2019, 08:44 PM
ben*james   Deposit made   Nov 26 2019, 08:38 PM
sixnotfour   Deposit made congrats..it was close to going to ...   Dec 5 2019, 10:16 AM
Cairo94507   Congratulations to Ben and Dominic. :beer2:   Nov 27 2019, 02:13 PM
ben*james   Congratulations to Ben and Dominic. :beer2: Th...   Dec 7 2019, 05:29 PM
Dominic   Congratulations to Ben and Dominic. :beer2: T...   Dec 7 2019, 07:55 PM
flat4guy   Congratulations - I am jealous of the new owners.   Nov 27 2019, 09:20 PM
914Love   This is my friends 914 out of Seattle...   Dec 5 2019, 04:56 AM
Cairo94507   You are welcome and my pleasure Dominic-- you have...   Dec 8 2019, 08:42 AM
ben*james   I've not stopped smiling since seeing and driv...   Dec 9 2019, 12:14 PM
porbmw   DAMN! NICE car! Congrats!   Dec 9 2019, 01:08 PM
71six   What ever became of this wonderful car?   May 14 2022, 04:39 PM
eric9144   What ever became of this wonderful car? @ben*ja...   May 14 2022, 10:44 PM
porsha916   hi, Is the vin: 9140430420, A 914/6 I owned from 1...   May 15 2022, 08:45 PM
71six   hi, Is the vin: 9140430420, A 914/6 I owned from ...   May 16 2022, 03:35 PM
Doug914   This is now on BAT . I think the selling dealer is...   Jan 10 2025, 09:02 PM
Dominic   Car looks great. It looks like Ben put a bunch of ...   Jan 11 2025, 01:40 PM
Doug914   It does look great. But I’m struggling to see ho...   Jan 12 2025, 04:40 AM
18 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th January 2025 - 01:35 PM
