Willisbegood |
Newbie ![]() Group: Members Posts: 26 Joined: 25-September 19 From: San Antonio Texas Member No.: 23,495 Region Association: South East States ![]() |
I recently posted a thread about lost compression on my 72 1.7 liter 914. I am currently seeking to drop the motor and replace the head gasket where I believe the leak is at however I came across this motor and wanted to know what your guys and (gals) thoughts are. Here is the 914 I have and this is the race motor I’m thinking about putting into it. (If I can get it for the right price). All comments are appreciated these are the motor specs..92x74 Race Engine. I have the build sheet. It's never been ran. It has 12.5: 1 Compression and FK-8 Engle Cam. Big Valve 42x37.5 heads with Dual 48 Dellortos.
Attached thumbnail(s) ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@Willisbegood
0 compression on one cyl? What are the numbers on all four? Might be time for a rebuild. These motors do not use head gaskets. They were used at the factory but discontinued use. Before you drop the engine check the valve train for problems that could cause the compression loss. Forget the race motor. It is a type I and does not fit a 914. And t b.f at is not a good street motor. |
Willisbegood |
@Willisbegood 0 compression on one cyl? What are the numbers on all four? Might be time for a rebuild. These motors do not use head gaskets. They were used at the factory but discontinued use. Before you drop the engine check the valve train for problems that could cause the compression loss. Forget the race motor. It is a type I and does not fit a 914. And t b.f at is not a good street motor. Thanks very much on the input for the race motor. Think I’m gonna scratch that one off. So It won’t stay running on its own so I did a compression test and I’m getting 60lbs in cylinder 1&2 and about 115lbs on 3&4. Also getting a lot more backfire than usual. It’s always had a little backfire when I got in earlier in the year and I was told it was just an exhaust leak. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:22 PM |
