> 74 914 Rustoration
eatpez
post Oct 28 2019, 08:16 PM
I picked up this roller last year and my brother picked one up as well. The original intension was a pair of Hayabusa builds, but I'm not so sure anymore, so I'm starting a new thread. The car was more or less complete and cheap. The longs and suspension points were solid, so I figure it was something I could work with.
Late this summer, I finally got back into the car, and the plan now is to take my time and make decisions as I go. Naturally, that means the first thing that needed to be done was to strip the car down to the bare chassis and tackle the rustoration first. This is especially interesting to me because the last time I restored a 914 was 25 years ago and I never got the chance to learn how to do body/suspension work. I'm using it as an opportunity to learn how fabricate and weld.
This will be my new thread and I'll be digging up pictures and posting updates with progress as I dig them up.
Superhawk996
post Nov 27 2019, 06:56 AM
Keep posting. How's this build going?
Garland
post Nov 27 2019, 08:18 AM
Restoration Fanatic
QUOTE(Superhawk996 @ Nov 27 2019, 07:56 AM) *
A Michigan build!
eatpez
post Dec 3 2019, 07:45 PM
Okay, pictures that I did take during the teardown and inventory of the chassis are coming with the next post. I wanted to mention the best addition to my tool arsenal for the project so far.
The lugs, suspension, steering rack, trailing arms, etc. gave me fits - the car had obviously been sitting (and rusting) for years. I tried, propane, PB blaster, mechanical leverage (up to 6-7' with cheater), and an air impact gun. No dice.
Once I got this setup, along with the #6 heating tip, all I ever needed to do was heat the stuck nut/bolt until it just started to glow red and every single time the fastener came loose without any issue whatsoever.
I wish I had this sucker 25 years ago when I did my last 914 project. All hail my trusty little HF oxy/acetylene torch!
eatpez
post Dec 3 2019, 08:12 PM
Here are the pictures I took during the teardown. The neighbor's cat was interested in what was going on - you can see the car has been through many colors and as I learned in going over it - also had many battle scars.
The rear panel was really weak in a few places, as well as the rear trunk pan, and I decided that I was going to replace the entire panel instead of doing the fabrication work to clean it up. More on that later.
The area blocked in red, more pictures to come, was evidence of an old accident where front half of the inner front fender was replaced but the damage also affected the area where the sway bar comes through as well as the bracket just under it. I've since found a donor piece to patch it in later. Thanks to Garold down in NW Indiana for hooking me up with some hunks off of one of his chassis (more pictures to come on that too).
The longs and suspension points were solid, but it I plan on replacing: rear panel, rear trunk pan, floor plan, front trunk floor plan in addition to the fab work to fix up the firewall and the engine bay (hell hole, battery tray).
Typical lower windshield rust.
eatpez
post Dec 3 2019, 08:25 PM
Here are a few examples of what I found during disassembly:
1. At some point someone thought it would be great to just weld in a piece of plate with a few stitches and the seat rails to that. The floor definitely needs to go and I'm considering boxing it in for re-enforcement. Those decisions will be deferred until after I have the chassis restoration done and decide on the powertrain.
2. A view of the inner passenger side front well - to the left of the pink line in the seam where the repair was made from accident damage, but the area circled in orange is also still out of shape and since this is where the sway bars come through and the a-arm attaches underneath, I've got a donor section that I'm going to swap in here.
In general, I'm working back to front on the chassis, mainly because I need to get the rear done so I can use the bumper mount points to get it up on a rotisserie.
eatpez   74 914 Rustoration   Oct 28 2019, 08:16 PM
pistorman   I have found myself pretty much in the same situat...   Oct 28 2019, 11:16 PM
ndfrigi   I’m also on the same status 74 project.   Oct 28 2019, 11:25 PM
Rogerz33   I’m also on the same status 74 project. T...   Dec 12 2019, 10:24 PM
Superhawk996   :wttc: Since you have a couple of Hayabusa's...   Oct 29 2019, 05:00 AM
eatpez   I don't have many pictures of the tear down, b...   Nov 5 2019, 07:45 PM
Superhawk996   :trophy: Keep posting. How's this build goi...   Nov 27 2019, 06:56 AM
Garland   :trophy: Keep posting. How's this build go...   Nov 27 2019, 08:18 AM
eatpez   Okay, pictures that I did take during the teardown...   Dec 3 2019, 07:45 PM
eatpez   Here are the pictures I took during the teardown. ...   Dec 3 2019, 08:12 PM
eatpez   Here are a few examples of what I found during dis...   Dec 3 2019, 08:25 PM
eatpez   Here are a few more pictures from the disassembly....   Dec 12 2019, 08:03 PM
eatpez   Here are some pictures from removal of the rear pa...   Dec 12 2019, 09:33 PM
eatpez   Next up was removing the rear half of the trunk pa...   Dec 12 2019, 10:04 PM
mepstein   The guys at the shop showed me how to make friends...   Dec 3 2019, 07:59 PM
bkrantz   Looks like we are are the same plan and state of p...   Dec 12 2019, 10:51 PM
eatpez   Post your build threads and I'll follow along....   Dec 26 2019, 04:08 PM
Superhawk996   Nice work. Keep going. Looks like you've got...   Dec 26 2019, 04:30 PM
jmitro   that's a lot of heavy metal work. reminds me ...   Dec 26 2019, 08:31 PM
- Lo-Fi Version Time is now: 27th December 2024 - 08:59 AM
