Brake proportioning valve. |
914Toy |
Dec 7 2019, 03:11 PM
Senior Member Group: Members Posts: 722 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Like most of our cars, the brake proportioning valve is 45 to 50 years old. While it's design and action is relatively simple, - holds the hydraulic pressure at a factory determined maximum value (550lb/square inch?) while under pedal pressure, the probabilities of function failure must exist - whether through wear or contamination.
In my case, my brakes work well and when bleeding them all four calipers appear to experience free flowing brake fluid. My proportioning valve does not leak and there are no signs of abuse, or that it has ever been "serviced", but the latter is hard to tell. My guess is it still works or is "seized" and works as a simple T connection for the three brake lines. I have refurbished stock rear brakes and have just installed Boxter front calipers on 911 Carrera suspension. Brakes are much improved and I can't get the rear brakes to slide under hard braking, suggesting the more effective front brakes "overpower" the rear brakes such that a proportioning valve is no longer necessary. Any comments will be welcome. |
Superhawk996 |
Dec 7 2019, 04:58 PM
914 Guru Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Brakes are much improved and I can't get the rear brakes to slide under hard braking, suggesting the more effective front brakes "overpower" the rear brakes such that a proportioning valve is no longer necessary. Any comments will be welcome. This suggests the proportioning valve is working. You still need a rear proportioning valve. If you were getting full pressure to the rear (without a proportioning valve) you would get rear wheel lock and especially so on wet pavement, snow, or ice. You never want rear wheels to lock 1st. It makes the vehicle inherently unstable. I highly recommend Eric's services. You want and need a functional proportioning valve. His price is incredibly resonable and ensures that the 40-50 year valve is working properly. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:03 AM |
