pastormacman |
Newbie ![]() Group: Members Posts: 28 Joined: 6-July 05 From: Bakersfield, CA Member No.: 4,382 ![]() |
Issue: There's no power going to the coil/fuel pump when I turn the key. (you can skip the history and jump down to the ALL CAPS and (IMG:style_emoticons/default/popcorn[1].gif) to see more about the issue)
History: 16 years ago, this was a running 1.7 fuel injected '73 in Bakersfield, CA. I bought it wrecked in the front end, (hood crunched a little, passenger fender dented) A friend straightened the trunk, cut off and welded a replacement fender on and we put on a replacement hood. I had it painted and new tires on it. It was my daily driver for a couple of years. 14 years ago, I got a new daily driver and this sat for a few months. Unbeknownst to me, a critter made it's home around one of the cylinders with mud and leaves. I went to drive it and the cylinder overheated and seized the engine. I bought new cylinders and took it to a friend to replace. Upon removing the engine he discovered that my block was cracked. I found a rebuilt 1.7 down in Los Angeles and bought it to replace the old engine. My mechanic friend was going to work on it in his spare time for me. I had always had trouble with the fuel injection, so I saw this as an opportunity to remove it and replace it with carbs. So he installed the carbs and after he got the engine back in the car, he discovered his dog had eaten the wiring harness (From the relay plate to the alternator/starter) At that point, life happened... kids grew up, I worked a lot and the car sat in that condition in one of the bays in his shop for 10 years. Three years ago, my sons are now teenagers, and I decided I wanted to finish it up and get it out of my friends way. He had kind grown resentful of it being there. I brought it home and put it on jack stands in my garage. I ordered a new wiring harness and tried to finish the car to get it started for my kids to drive. I discovered that through life I had developed a strong case of claustrophobia and it's difficult to get under the car for me. So it has sat for another three years. So I have a new friend who rebuilds VW Bugs who is now helping me.We've gotten all the electrical hooked back up. Removed the gas tank and flushed it out. replaced all the fuel lines, and filters. And got a new battery. Which brings me to the present... (IMG:style_emoticons/default/popcorn[1].gif) ISSUE: WHEN WE TURN THE KEY, THERE'S NO POWER TO THE COIL OR FUEL PUMP. Since we replaced the fuel injection with carburetors, we no longer have the ECU in the car. (in fact, I no longer have the ECU or any of the fuel injection parts anymore, they are long gone at my other friends garage) Not sure if that was a mistake, I thought I didn't need it anymore since the FI was gone. My VW friend is not familiar enough with 914 electrical to find the issue. Could I have a bad relay? I see that there is a port for the white wires from the ECU to connect to the relay panel. Is there a part I need there in place of the ECU wiring? Is this a common issue with a carb replacement? Other electrical things work, (headlights, and whatnot) and if I continue to turn the key, the starter starts to crank, but no power to the coil/fuel pump. Any help would be appreciated. Sorry for the long post. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
In your original post you said you had no power to either the coil or fuel pump. If fuse #9 under the dash is not good and passing power to pin #8 of the 14 pin connector at the relay board, neither the coil will have power nor the fuel pump. Pin #8 feeds power to the POWER relay on the relay board witch in turns passes power to the fuel pump relay. Check that there is power at Pin #8 with the key switch on.
Tom EDIT: I was looking at my prints and I was wrong. The power to pin 8 of the 14 pin connector does come from fuse #9, but it is from the un-fused side ( or hot side). One would still need to confirm that when the key is turned on, there is power at pin #8 of the 14 pin connector for the relay board and at the power relay thru the relay board traces and on to the fuel pump relay. Tom |
Lo-Fi Version | Time is now: 26th April 2025 - 02:53 AM |
