> Headlight gremlins
john77
post Dec 10 2019, 06:26 PM
My headlights have decided to randomly turn themselves on and off as I drive, which is a lot of fun at night on the I405 as drivers think some obnoxious d*ck is flashing them.
I cleaned up the grounds and all the ground wire connectors by both headlights but it’s still happening.
Could this be relay connected, or are they more a once dead completely dead kind of deal?
I thought i’d ask before I drop $20 on a new one.
For the record, I have those sealed GE led headlights, and it’s happening simultaneously to both, so I know it’s not the bulbs.
john77
post Dec 11 2019, 12:24 AM
@spoke Am I reading that diagram right, the fogs only come on when the high beams are on?
lierofox
post Dec 11 2019, 02:05 AM
QUOTE(john77 @ Dec 10 2019, 10:24 PM) *
It's one of those wonky to understand, but very useful circuits.
The ground side of the fog lamp relay is connected to the positive side of the high beam circuit. When the high beams are off, the high beam circuit is dead, so the relay is able to find ground by going through the high beam filament (the current going through the relay coil is so low because of the coil's high resistance (not even 1 amp) that it's not nearly enough to make the high beam filament glow.)
When the high beams are turned on, the supply side of the high beam circuit suddenly becomes 12 volts. Since the fog light relay coil has 12v on one side, and 12v on the other side, the difference between 12v and 12v is... 0 volts, so the relay turns off, and kills the fog lights!
Because bulb filaments work differently from LEDs, this circuit can break spectacularly when you replace the headlights with LEDs.
john77
post Dec 11 2019, 09:05 AM
QUOTE(lierofox @ Dec 11 2019, 12:05 AM) *
Wow, I didn’t know this... and it just gave me a headache trying to understand it.
So my best bet if I want to run fogs with the LED headlines is to completely separate the two circuits and run the fog switch directly to the fog relay?
lierofox
post Dec 11 2019, 12:01 PM
QUOTE(john77 @ Dec 11 2019, 07:05 AM) *
You just have to pull the fog relay's ground wire off the high beam terminal, and move it over to a dedicated ground lug, then it'll always be grounded and the high beams won't cancel it.
Edit: Here's a little interactive/animated diagram I made demonstrating the circuit, you can click on the switch to turn it on and off, the wire colors show where the voltage is (green is 12v, gray is ground) and the yellow dots show the current flow.
http://tinyurl.com/tj74k43
john77   Headlight gremlins   Dec 10 2019, 06:26 PM
Spoke   Are they off and turning themselves on? Or on and...   Dec 10 2019, 06:53 PM
john77   Are they off and turning themselves on? Or on an...   Dec 10 2019, 07:29 PM
taylspin46   Sounds like headlight switch contacts. Pull switch...   Dec 10 2019, 07:47 PM
john77   Sounds like headlight switch contacts. Pull switc...   Dec 10 2019, 07:57 PM
bdstone914   @john77 My bet is the switch. The lights have se...   Dec 10 2019, 07:56 PM
john77   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 10 2019, 08:19 PM
SirAndy   Could this be relay connected, or are they more a ...   Dec 10 2019, 08:03 PM
john77   Could this be relay connected, or are they more a...   Dec 10 2019, 08:08 PM
Costa05   [quote name='SirAndy' post='2768867' date='Dec 10...   Dec 10 2019, 09:18 PM
Spoke   Here's the circuit for a '74 914. Likely t...   Dec 10 2019, 09:14 PM
john77   Here's the circuit for a '74 914. Likely ...   Dec 11 2019, 12:09 AM
john77   @spoke Am I reading that diagram right, the fogs ...   Dec 11 2019, 12:24 AM
SirAndy   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 11 2019, 01:29 AM
lierofox   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 11 2019, 02:05 AM
john77   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 11 2019, 09:05 AM
lierofox   Wow, I didn’t know this... and it just gave me ...   Dec 11 2019, 12:01 PM
john77   Wow, I didn’t know this... and it just gave me...   Dec 11 2019, 04:27 PM
lierofox   That makes sense. Moving the fog relay ground w...   Dec 11 2019, 04:42 PM
Mikey914   If it's the lights (both going up and down), i...   Dec 11 2019, 12:52 AM
FlacaProductions   There's a ton of info here on the LED headligh...   Dec 11 2019, 10:14 AM
john77   There's a ton of info here on the LED headlig...   Dec 11 2019, 11:40 AM
dr914@autoatlanta.com   probably the headlight switch or the high low beam...   Dec 11 2019, 10:19 AM
AZBanks   Hijacking the thread since my issue is light relat...   Dec 11 2019, 12:08 PM
john77   Hijacking the thread since my issue is light rela...   Dec 11 2019, 04:15 PM
Mikey914   Hijacking the thread since my issue is light rela...   Dec 11 2019, 04:53 PM
john77   I took the car out last night. Still no conclusive...   Dec 12 2019, 10:15 AM
lierofox   I took the car out last night. Still no conclusiv...   Dec 12 2019, 12:33 PM
Spoke   I took the car out last night. Still no conclusiv...   Dec 13 2019, 08:30 AM
john77   I took the car out last night. Still no conclusi...   Dec 13 2019, 11:37 PM
AZBanks   I went out to check the relays. Before I touched a...   Dec 12 2019, 08:30 PM
djway   This thread gave me a headache :chair: I have a...   Dec 13 2019, 11:30 PM
- Lo-Fi Version Time is now: 23rd September 2026 - 01:21 AM
