New Heads unpacking, Camper Specials from Type4Store |
malcolm2 |
Dec 10 2019, 09:27 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I figured this group might enjoy seeing my Christmas present to myself. These are for my 72 VW bus. They cost more THAN my bus. LOL.....I did not opt for the Ceramic coating. But as stated these are Camper Specials, New 1.8 AMC castings, Type4store's 2 liter sized SS valves, springs, keepers, etc... modified ports, proprietary valve seats that you can see are inserted deeper, plus a notch for an under plug CHT thermocouple.
Still to come is a Type4store 9590 cam kit with cut to fit Chromoly push rods, solid lifters, swivel foot adjusters, I forget what else. Merry Christmas to me. (IMG:style_emoticons/default/piratenanner.gif) |
Bleyseng |
Dec 11 2019, 09:57 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too.
malcolm2 |
Dec 11 2019, 10:03 AM
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too. What pistons and crank do you have in your bus? I am considering getting new rings and putting the 93mm pistons back in with the stock 66mm crank. I bought some rings but the bottom ring assembly was 4mm thick. too big for the 3mm trough. Sent them back and suggested that they stop selling them as suitable for 93mm type 4 pistons. |
Bleyseng |
Dec 11 2019, 01:03 PM
Len won't rebuild old castings! These are new AMC 1.8L heads that he rebuilds. I am running a set in my 77 Westy, definately the way to go to run cooler with the 9590 cam setup too. The 100+ hp in a bus is really nice too. What pistons and crank do you have in your bus? I am considering getting new rings and putting the 93mm pistons back in with the stock 66mm crank. I bought some rings but the bottom ring assembly was 4mm thick. too big for the 3mm trough. Sent them back and suggested that they stop selling them as suitable for 93mm type 4 pistons. I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! |
malcolm2 |
Dec 11 2019, 01:44 PM
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! 3 choices for me.... buy 93mm rings ($50) 1756 cc or 96mm P/C ($400 non-nickies) 1911 cc or 71mm crank, 96mm p/c ($700) 2056 cc EDIT: and 2.0 rods ($300 more) Further edit: I guess I could go full 2.0 and just use 94.5mm P/C 1985 cc? I am in this deep, maybe I should go 2056? |
jcd914 |
Dec 11 2019, 07:36 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I am running AA 914 94mm USA style with the small dish. CR is 7.5 to 1. Head temps are great and it has 50,000 miles on it now. Why run the 1.8 stuff as the extra torque is a must in a bus! Go 2.0l ! 3 choices for me.... buy 93mm rings ($50) 1756 cc or 96mm P/C ($400 non-nickies) 1911 cc or 71mm crank, 96mm p/c ($700) 2056 cc I am in this deep, maybe I should go 2056? You need to include 2.0L rods with the 71mm crank and 96mm P&Cs to get your 2056. Your 1.7 rods won't work with teh 2.0 crank. 2056 would be my choice. Jim |
malcolm2 |
Dec 12 2019, 07:53 AM
You need to include 2.0L rods with the 71mm crank and 96mm P&Cs to get your 2056. Your 1.7 rods won't work with teh 2.0 crank. 2056 would be my choice. Jim Yep, I knew that. That is what happens when you start adding up the $$$ you always forget something. I guess that takes my 71mm crank scenerios up another $100 to $300. Let's just say to another even $1000. This bus is worse than a BOAT. Bring Out Another Thousand ! |
Bleyseng |
Dec 12 2019, 11:01 AM
You need to include 2.0L rods with the 71mm crank and 96mm P&Cs to get your 2056. Your 1.7 rods won't work with teh 2.0 crank. 2056 would be my choice. Jim Yep, I knew that. That is what happens when you start adding up the $$$ you always forget something. I guess that takes my 71mm crank scenerios up another $100 to $300. Let's just say to another even $1000. This bus is worse than a BOAT. Bring Out Another Thousand ! Since it's a 72 Bus does it still have the early trany? |
malcolm2 |
Dec 12 2019, 11:10 AM
You need to include 2.0L rods with the 71mm crank and 96mm P&Cs to get your 2056. Your 1.7 rods won't work with teh 2.0 crank. 2056 would be my choice. Jim Yep, I knew that. That is what happens when you start adding up the $$$ you always forget something. I guess that takes my 71mm crank scenerios up another $100 to $300. Let's just say to another even $1000. This bus is worse than a BOAT. Bring Out Another Thousand ! Since it's a 72 Bus does it still have the early trany? I am not sure. I sent the tranz out to get magic worked on it. Turns out all those years sitting in a field, caused the inside to drastically pit. Magnesium and water don't mix. So my guy is putting together a rebuilt one for me. aren't the "ribs" how you know? I think it had 6 ribs. Mfg date was 11/71 for the bus. He and I talked alot about going with a Freeway Flyer. That is what he is making and he suggested getting as much displacement as I could. He seems to think the FF works best with more power. So 1.8 was OK, 1911 was better, so I am sure 2056 would be even better. Decisions, decisions.... |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:10 PM |
