motorvated |
Member ![]() ![]() Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
Any recommendations for a good piston ring compression tool that I can use on my 2.0 and 1.8 liter Type IV motors? I've had a couple of them and neither has worked very well on other applications, and the one I now have is giving me problems getting the pistons back into the cylinders with the new rings in place on the 2.0 liter motor.
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
They all work pretty much the same. The trick is using enough oil/lube, and the speed with which you push the piston in. I’m no engine expert, but I’ve had good luck using the handle end of a mallet to push the piston down till the skirt is in the cylinder and the bottom ring is just above the lip, then give the top of the mallet a good rap with a BFH. You have to have enough speed for the ring to “jump” in.
Lo-Fi Version | Time is now: 25th June 2024 - 01:11 AM |
