> fan belt problems
jat914
post Dec 15 2019, 02:20 PM
I had to replace the fan belt on my race built 2065 motor. The replacement belt is made in China and at high rpms it kept flying off! Has anyone had this problem and is there a solution?
jcd914
post Dec 17 2019, 04:27 PM
This was a fairly common issue for track use or auto-x drivers since quick RPM changes were common. Even with all the brackets and pulleys in good shape and properly aligned the high RPM could throw the belt just from normal stretch.
On track cars or Auto-x only cars we used to run a narrower belt that fit deeper in the pulley and was less likely to come off at high RPM.
It was a domestic sized belt that I think was 7/16 wide or about 8mm but I am not sure.
These did not have lifespan a belt should have for a street car but they stayed on track/auto-x cars.
I still have an old one but I don't think it has numbers on it anymore.
Jim
jat914
post Dec 19 2019, 02:50 PM
QUOTE(jcd914 @ Dec 17 2019, 03:27 PM) *
Jim
I will try a thiner belt (8mm) since the alignment was fine before I started having this problem. Thanks for all of the input.
porschetub
post Dec 20 2019, 02:22 PM
QUOTE(jat914 @ Dec 20 2019, 09:50 AM) *
Jim
After Marks comment about belt size I checked my supply and also found an 8 X 965mm,tryed it on my spare T4 motor (next build) and as Jim mentioned it fitted better in the grooves ,and was level with the top of both pulleys,even being a bit worn the adjustment was about centre on my altenator top bracket
Considering any part of the belt not fully contacting the pulley vee's is lost drive ,perhaps the narrower belt is the way to go.
- Lo-Fi Version Time is now: 27th December 2024 - 08:16 PM
