> is a leak-free Type IV possible?
jmitro
post Dec 21 2019, 08:01 PM
my 2056 Type IV leaks a couple of 3-4" oil spots every time I drive it, which is a couple days a week lately. the drain plug has a new copper washer, and the taco plate has new rubber and paper gaskets with gasket sealant.
I think the leak is from the case halves. Mobil1 10W-30. Would a higher weight oil make a difference?
Man, I hate oil leaks!
injunmort
post Dec 21 2019, 08:55 PM
can a 60's era british motorcycle be made leak free? the answer is, I am afraid, no. too many mating surfaces, paper gaskets, heat cycling, they will all leak eventually. it can be mitigated with sealing compounds, proper lubricants and careful assembly, but its going to leak. 10-30 synthetic is too thin, 20-50 dino will slow the drip and dissipate heat better. originally designed to run straight 30wt or 50 wt depending on climate.
jmitro   is a leak-free Type IV possible?   Dec 21 2019, 08:01 PM
914forme   Yes, did it for many years when I auto-Xed my 914-...   Dec 21 2019, 08:24 PM
914forme   If it is a case leak, then you will have to split ...   Dec 21 2019, 08:25 PM
injunmort   can a 60's era british motorcycle be made leak...   Dec 21 2019, 08:55 PM
KELTY360   can a 60's era british motorcycle be made lea...   Dec 21 2019, 11:38 PM
oakdalecurtis   I’ve owned my stock 76 2.0 with 120,000 miles fo...   Dec 21 2019, 09:02 PM
TheCabinetmaker   I rode a 62 bsa 650 pre unit construction for many...   Dec 22 2019, 12:28 AM
TheCabinetmaker   Oh yeah, 914 doesn't leak oil either   Dec 22 2019, 12:28 AM
JawjaPorsche   I heard 914s stop leaking oil when they run out of...   Dec 22 2019, 04:35 AM
Jett   We have three drivable 914’s and only one leaks ...   Dec 22 2019, 08:55 AM
injunmort   not to be argumentative but I have never dropped a...   Dec 22 2019, 10:28 AM
KSCarrera   Fully-synthetic oils will create leaks, which is o...   Dec 22 2019, 11:27 AM
jmitro   Try swapping to a semi-synthetic – or a modern m...   Dec 22 2019, 12:19 PM
porschetub   Fully-synthetic oils will create leaks, which is ...   Dec 22 2019, 01:19 PM
Jamie   I hesitate to say this, but the only oil leak my 7...   Dec 22 2019, 12:33 PM
bandjoey   OT: I thought at first you were talking about le...   Dec 23 2019, 11:36 AM
DRPHIL914   Very possible. I have been leek free since droppin...   Dec 23 2019, 12:03 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 11:41 PM
