63acornwall |
Member ![]() ![]() Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None ![]() |
looking at the interior of door , no obvious screws to remove door panel and top padded rail ? Is there an existing thread for this ?
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Both sides, there are 3 screws along the bottom of the armrests, then then there are plastic plugs along F & rear sides that will pop out. then lift vertically to release tangs along the top edge. Of course, the window crank & the recess under the interior lock/opener handle screws need to com out. The window crank plastic cover will lift away for access to the screw under.
914 rubber sells new plastic & silicone bits that will probably break when you pull the door cards away. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:01 PM |
