0-60 for a 914/6 with 3.2? |
Tdskip |
Dec 22 2019, 01:45 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
The numbers are secondary to the driving experience of course, but just curious if anyone’s ever benchmark to their conversion against a stopwatch?
Coondog |
Dec 22 2019, 02:38 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
I would think a six mated to a 915 trans would show much better 0 to 60 numbers.
mepstein |
Dec 22 2019, 02:52 PM
914-6 GT in waiting Group: Members Posts: 19,650 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would think a six mated to a 915 trans would show much better 0 to 60 numbers. Correct. I’ve driven a bunch of light weight 911’s with hot 3.2’s and 915 trans and it’s a blast. No tip toeing around first and slipping the clutch to start in second. But unfortunately it’s a lot more work and money to do it in a 914. Steve Timmons/Instant-G/3.6 conversion shop took me out in one of his hot 3.8 cars and it was a whole nother level. BIG torque. He showed his transmission no mercy and it held up fine. |
SirAndy |
Dec 22 2019, 03:12 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I would think a six mated to a 915 trans would show much better 0 to 60 numbers. Correct. I’ve driven a bunch of light weight 911’s with hot 3.2’s and 915 trans and it’s a blast. No tip toeing around first and slipping the clutch to start in second. But unfortunately it’s a lot more work and money to do it in a 914.Taking off in 2nd has the advantage that you don't need to shift at all. The stock 901 gearing will get you from 0 to 60 without shifting (With the appropriate redline and wheel/tire sizes). The 901 seems to be able to handle the torque just fine if you skip 1st ... (IMG:style_emoticons/default/driving.gif) |
Tdskip |
Dec 22 2019, 07:17 PM
Taking off in 2nd has the advantage that you don't need to shift at all. The stock 901 gearing will get you from 0 to 60 without shifting (With the appropriate redline and wheel/tire sizes). The 901 seems to be able to handle the torque just fine if you skip 1st ... (IMG:style_emoticons/default/driving.gif) Thanks @SirAndy , I will keep that in mind. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:39 PM |
