Rebuiding Inside-out |
bkrantz |
Oct 16 2019, 08:47 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I realize most rebuilds go from the inside to the outside, but I am struck by how straight and clean the outer panels, including paint, look on my 73 2.0. And all the nasty stuff is hidden underneath--which I know is also not unusual.
Any way, I bought the car knowing most of what it was: a 2.0 with all the sport and appearance group equipment, including 5 good Fuchs, and the original fuel injection. The original engine is confirmed by a COA. In contrast to the exterior the interior was mixed at best, with some funky carpet. And the front and rear trunks (and engine compartment, and interior) had been sprayed with black undercoating. So after a month, I have the car stripped to a bare shell, except for suspension and steering. I measured everything I could, and the body is very square and on spec. I need to patch some local rust spots, and replace the rear floor. And then do some minor straightening: right headlight bucket, front edge of right front fender, rear panel, etc. Attached thumbnail(s) |
bkrantz |
Dec 22 2019, 09:35 PM
Decided to separate, in order to make it right. This also gives me better access to finish work on the inner fender. Pretty easy since the fender was only attached at the lap joint, some brazing around the tail light opening, and one spot of brazing on the top seam.
Lo-Fi Version | Time is now: 25th June 2024 - 01:10 AM |
