Two in-line fuel filters, Is this a problem for 3.5 psi rotary fuel pump? |
dcecc1968 |
Dec 23 2019, 10:15 AM
Member Group: Members Posts: 253 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
I have a 1.7 dual-carbed set up and I'm getting ready to change my facet fuel pump for a CMB rotary fuel pump. The PO moved the fuel filter to the top of the engine for ease of access, but my new CMB pump has one installed at the pump that is "supposed" to remain or the 1-yr warranty is invalidated.
Is it a problem to leave both filters in place or will that create too much pressure drop. I'm trying to do the pump switch-out without having to cut / re-plumb the fuel hosing. Also, is it better to have the fuel filter between the tank and pump or between the pump and carbs? |
rhodyguy |
Dec 23 2019, 10:35 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,195 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Change the crimped clamps and short piece of hose on the filter to pump. New short piece of fuel line and stock shouldered clamps. Imho the second filter between the pump and carbs is not needed if you start with a clean fuel tank and a NEW in tank mesh/filter sock. Rotary914 usually has the socks and fiber washers in stock.
Lo-Fi Version | Time is now: 27th December 2024 - 07:14 PM |
