> Foam and undercoating, How to remove undercoating and foam
kroelofsen
post Dec 23 2019, 12:59 PM
Region Association: Europe
Hi everyone,
Started today to remove some undercoating in the rear wheel arches, see picture...
When using a (blunt) chisel is comes of rather easily. Any advise on removing it in the corners of the arches…? Especially in the rear it is almost impossible to reach the far corners...
I also found the foam in the rear of the panels near the rear lights (yellow circle). With a hook I'm picking it out. Any tips on doing this more easily…?
Till now I did not find any rust. The car is from 12/73 and 1.8 L-jet in olympic blue.
Superhawk996
post Dec 23 2019, 03:35 PM
QUOTE(kroelofsen @ Dec 23 2019, 01:59 PM) *
Per Jeff Hail recommendation Wurth DBS 3600 with the wire flail wheel simply tears though the factory seam sealer and makes easy work of it. It is pricey but worth it. There are 1/2 price alternatives though Eastwood and one other place (forget the name).
https://www.wurthusa.com/Tools/Air-Tool-Par...Case/p/07033601
All depends on what your time is Wurth (pun (IMG:style_emoticons/default/laugh.gif) ). It tears simply tears though undercoating even easier without damaging the metal below it. Other methods work but this tool as designed for professional use for exactly this task where time = money.
- Lo-Fi Version Time is now: 27th December 2024 - 10:53 PM
