It's on PMs sent -GB for Trailing Arm bushings Rubber and option for Urethane, Who's interested? 4 pcs (one car) $28 a set rubber $36 Poly |
Mikey914 |
Nov 18 2019, 04:08 PM
The rubber man Group: Members Posts: 12,739 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We are in the process of doing the A arm bushings in rubber
We can easily do these up in a polyurethane at the same time, just have to do enough to pay for the materials and set up would be looking at 25 sets to do the Poly The GB would be for a set of 4 (enough for 1car) For $28 in rubber and $36 in poly To get the pricing right we need 40 takers in rubber and 25 in Poly We've been in testing on these for some time and had made a couple variations. This is what they look like. SO Who's in? Attached image(s) |
Mikey914 |
Dec 24 2019, 05:38 PM
That's a 911 bushing, they are different. I'm hesitant to redesign this with just a change of a bushing. The factory spent a lot of time and energy making these, and there wasn't a superseded part. That means they were the best balance of performance and economy for at least a daily driver. We can make a shaft that utilizes a bearing to allow rotation. Could use either poly or natural rubber. Considering the OEM rubber lasted 30 years + the difference between the 2 is nominal, again if we can get at least 25 sets, I'll gladly do them.
Do look for the bearing option for the shafts . I'll delay this till next week as we will be running them shortly. So for non binding shaft please indicate your interest we will run 10 sets like this. Mark |
Lo-Fi Version | Time is now: 17th December 2024 - 01:53 AM |
