> MaxJax Black Friday promo?, Looking for a deal. Post up car related BF deals here.
VaccaRabite
post Nov 26 2019, 05:16 PM
En Garde!
I want a MacJax lift for my garage. I want to buy it Friday/Monday.
Who has seen deals for it?
If you have seen other killer deals for BF/CM post them up here.
Zach
post Dec 27 2019, 07:11 PM
1) Depth of concrete is a no brainer. Drill a hole then measure thickness.
2) I recommend you have 2 hammer drills. One smaller one with a 1/4" x 6" bit and a 30#-40# hammer drill for the actual hole size needed. Lay out where you want it to sit and mark the holes. Now take the small hammer drill with a 1/4" bit and drill center of each hole. If it stops penetrating pull the bit out and check for grey dust. If you see grey dust you're on rebar or post tension steel. Drill all 8 holes then determine where and how many spots have steel beneath them. If none, Bingo. But more than likely you will hit at least one piece of steel and then you will need to shift the location of the holes an amount that will get you in the clear. Before shifting the hole locations only to find out that you've ended up upon another piece of steel do this. Using one of the 1/4" holes as a starting point drill another hole at a slight angle. If it clears then you know where the steel is and isn't thus preventing a Swiss cheese effect in your slab. If it turns out that you can't relocate w/o being on top of a piece of steel then you can have one or 2 anchors installed on a slight angle. You will need no make a washer that is beveled so that you can tighten the bolt w/o having the edges of the bolt head strike the plate preventing you from tightening the anchor completely.
3) They ship 8 anchors and no spares so take your time. Those anchors aren't going to be at your local hardware store and they're pricey to boot. If any of the local boys want to install one feel free to borrow my big hammer drill. (IMG:style_emoticons/default/beerchug.gif)
VaccaRabite   MaxJax Black Friday promo?   Nov 26 2019, 05:16 PM
914forme   https://www.asedeals.com/store/dannmar-port...ar-l...   Nov 26 2019, 06:32 PM
Mikey914   I like the idea of putting a lift in. But I can se...   Nov 26 2019, 06:40 PM
Lucky9146   I like the idea of putting a lift in. But I can s...   Nov 27 2019, 11:44 AM
mepstein   I think Ben got his for around $1600 on a Hom...   Nov 26 2019, 07:07 PM
mb911   I bought mine on a flash sale from danmar/maxjax f...   Nov 26 2019, 07:12 PM
VaccaRabite   I have 8 inch thick floor on one side, and 4 inch ...   Nov 26 2019, 07:14 PM
mb911   I have 8 inch thick floor on one side, and 4 inch...   Nov 26 2019, 08:06 PM
cuddy_k   be careful...thickness of the slab is only one fac...   Nov 26 2019, 11:51 PM
Mikey914   Yes adding a plate for support would help spread t...   Nov 27 2019, 01:25 AM
mb911   We used 3000 psi concrete when pooring the shop fl...   Nov 27 2019, 05:39 AM
A&P Mech   I really like mine. It makes dropping an engine ou...   Nov 27 2019, 06:26 AM
A&P Mech   Here is a picture of my car with the lift at the u...   Nov 27 2019, 06:31 AM
914four   If you have seen other killer deals for BF/CM pos...   Nov 29 2019, 12:49 PM
mb911   If you have seen other killer deals for BF/CM po...   Nov 29 2019, 12:59 PM
914forme   This is the last price I got MaxJack   Nov 29 2019, 06:35 PM
VaccaRabite   Pulled the trigger a few minutes ago at 1749 (...   Nov 29 2019, 07:51 PM
914four   Checking to see if anyone has received their Black...   Dec 27 2019, 04:48 PM
VaccaRabite   Checking to see if anyone has received their Blac...   Jan 2 2020, 10:50 AM
914four   Hey Kelvin, I just got the call that mine will be...   Jan 5 2020, 09:42 AM
VaccaRabite   Nope. Don’t have mine yet. I talked with them ...   Dec 27 2019, 04:51 PM
76-914   1) Depth of concrete is a no brainer. Drill a hole...   Dec 27 2019, 07:11 PM
VaccaRabite   Mine was delivered late (7pm) Monday evening. Sti...   Jan 9 2020, 10:00 AM
914four   Delivery notice came by e-mail for Tuesday. :D   Jan 11 2020, 09:50 AM
914four   We have lift-off! :trophy:   Feb 9 2020, 04:49 PM
DRPHIL914   We have lift-off! :trophy: I really want ...   Feb 9 2020, 05:20 PM
914four   I really want one of these! Looks great, how ...   Feb 9 2020, 06:13 PM
VaccaRabite   I got mine up and running too this weekend. I th...   Feb 9 2020, 07:47 PM
sb914   Smart button to the right!   Feb 9 2020, 08:01 PM
mb911   Did either of you use the epoxy anchors? I am moun...   Feb 9 2020, 08:01 PM
VaccaRabite   Did either of you use the epoxy anchors? I am mou...   Feb 10 2020, 07:18 AM
mb911   Did either of you use the epoxy anchors? I am mo...   Feb 10 2020, 07:21 AM
914four   Did either of you use the epoxy anchors? I am mou...   Feb 10 2020, 08:03 PM
mb911   Did either of you use the epoxy anchors? I am mo...   Feb 10 2020, 08:07 PM
DRPHIL914   what is the "best price" on these as I s...   Feb 10 2020, 08:34 AM
VaccaRabite   what is the "best price" on these as I ...   Feb 11 2020, 09:53 AM
mepstein   what is the "best price" on these as I...   Feb 11 2020, 10:14 AM
mb911   [quote name='VaccaRabite' post='2784990' date='Fe...   Feb 11 2020, 10:18 AM
VaccaRabite   I see one in my future next time black friday ro...   Feb 11 2020, 10:23 AM
76-914   [quote name='VaccaRabite' post='2784990' date='Fe...   Feb 11 2020, 10:31 AM
32 User(s) are reading this topic (32 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 14th January 2025 - 06:13 PM
