3.0 /6 in storage the case is filing with oil, and starting to leak on the floor. |
Mark Henry |
Dec 26 2019, 12:51 PM
So my '74 /6 conversion with the DWD sump tank is slowly leaking down into the engine sump. I have a leaking #6 rocker shaft that I'll have to R&R so I know my engine is full to at least to the exhaust rockers. I know it doesn't drain enough to do this if I drive at least weekly. I have a buddy who's well worn engine has hydrolocked a few times due to this.
I had to start and move the car, quite the smoke show. Only automatic cure I've seen so far is a $300 valve from Rothsport. Or I could just install a ball valve and red tag my dash for just over $20. I know it's a common 911 issue, do you other /6 owners have this issue and what do you do about it? |
gereed75 |
Dec 28 2019, 10:47 AM
Senior Member Group: Members Posts: 1,315 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Would That improved racing check valve be a good alternative to the 3x more expensive Rothsport valve (available for slightly less from Wilhoit)?
Can’t quite get my head around what you would need to fit it into a 6 oil feed line - a female fitting that fits the line and then an AN to metric adapter at the other end. By the time you do that you are almost at the price of the Rothsport valve. Anyone have any further experience with that? |
sixnotfour |
Dec 28 2019, 11:42 AM
914 Wizard Group: Members Posts: 10,682 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Would That improved racing check valve be a good alternative to the 3x more expensive Rothsport valve (available for slightly less from Wilhoit)? Can’t quite get my head around what you would need to fit it into a 6 oil feed line - a female fitting that fits the line and then an AN to metric adapter at the other end. By the time you do that you are almost at the price of the Rothsport valve. Anyone have any further experience with that? that check valve has a 1lb opening rate the facory/rothsport is 3lbs,,,and since its a check flapper , you would actually have to install it backwards..... Its the continual flow from the tank is what is trying to be lightly blocked when not running.. ie keeps the oil in the tank..at rest...little to no restriction while running.... Im gonna use the manual ball valve also..mine will be right below trunk floor ,,so the handle can be inside the rear trunk... My setup is kinda odd, But I have a huge front trunk... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 10:00 PM |
