Runs for a few seconds and dies |
aexe |
Dec 14 2019, 10:01 PM
Newbie Group: Members Posts: 10 Joined: 28-December 18 From: San Francisco Member No.: 22,756 Region Association: Northern California |
Hey all. Hoping for some advice on a intermittent issue I'm having lately. 1974 1.8L L-Jet with Pertronix Ignitor electronic ignition. Full disclosure, I AM overdue for a valve adjustment.
Six weeks ago I was a few blocks from home and the car completely died, like I had shut the key off. Coasted to the curb, spent 2 hours trying to get her to start without luck. Left overnight. Walked home. Walked back in the morning and she started right up and drove with no issues for weeks. This morning after my coffee stop near work, she did the same thing. Started up and then died completely. Would not start again. Left there and walked to work. Went back in the afternoon and she started right up no problem. Drove to 20 minutes to my shop space with the intent to swap to a new ignition switch, as I thought this might be the issue, as well as changing out the AFM as I had ordered a new one due to some FI issues I've been chasing. Replaced both this afternoon. Tested and fired right up, solid idle. An hour later I drove home, about 10-12 minutes. As I was pulling into the garage, the idle dropped but I was able to catch it and pulled into a spot. I spent the next half hour starting and restarting the car, finally taking this video for a reference. The car starts and runs for a few seconds, the idle sways, almost recovers and then shuts off, regardless of throttle position it seems. I was also checking voltage from the alternator to the battery which above idle seems to be in the mid 13's. Also, it was raining on the way home if that matters. I would love ANY thoughts on the car's behavior in this video. Stumped. Thanks in advance. https://youtu.be/kkCBQGRhI5s |
porschetub |
Dec 29 2019, 08:26 PM
Advanced Member Group: Members Posts: 4,756 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sorry but you can't test a coil,if the windings are bad it will only show up after you have run for a while which was obviously your issue ,plug leads break down in a similar way also.
If your timing is set correctly then do your valve setting then move on to how the FI is working,you need a good baseline to start with otherwise you are chasing your tail with other issues. I would expect you will be looking for air leaks after that ,no afm based injection will tolerate leaks and will always revert to a high idle. L-jet reponds on movement of the air gate on cranking to start the fuel pump via the ecu signal from the throttle position switch,no air and the fuel pump afm contact is in the game (closed ) and it won't run the pump. Think thats right if not correct me...happy new year. |
Lo-Fi Version | Time is now: 28th December 2024 - 12:08 AM |
