Fuel injector mystery and manual recommendations |
Robson51 |
Dec 29 2019, 09:01 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
In the process of running down one thing after another, took the ‘74 2.0 out for a drive. Had a miss, so pulled the plugs. This car has spent a lot of the last 9 years sitting, so gas tank has been cleaned and fuel lines changed.
#2 showed where a plug wire was barely attached which was quickly fixed, but the #3 plug was white. I mean really white. Like zero fuel lean. After looking at the connection to the injector, I saw the boot was ripped and the connection was pretty dirty, so I took i apart and sprayed electrical cleaner in it Drove it a couple miles, still had a miss, but when I pulled the #3 plug now it was black. Did I wake something up? Pulling the engine soon to fix oil leaks, so is it worth it to pull all the injectors and get them rebuilt? I have no idea what’s going on here. On another note, what’s the best manual for a 914 2.0? TIA Rob |
rhodyguy |
Dec 29 2019, 11:01 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you want to service the injectors 'Witch Hunter' is located in Duval.
Robson51 |
Dec 30 2019, 01:07 AM
Lo-Fi Version | Time is now: 25th September 2024 - 10:41 PM |
