Robson51 |
Member ![]() ![]() Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest ![]() |
In the process of running down one thing after another, took the ‘74 2.0 out for a drive. Had a miss, so pulled the plugs. This car has spent a lot of the last 9 years sitting, so gas tank has been cleaned and fuel lines changed.
#2 showed where a plug wire was barely attached which was quickly fixed, but the #3 plug was white. I mean really white. Like zero fuel lean. After looking at the connection to the injector, I saw the boot was ripped and the connection was pretty dirty, so I took i apart and sprayed electrical cleaner in it Drove it a couple miles, still had a miss, but when I pulled the #3 plug now it was black. Did I wake something up? Pulling the engine soon to fix oil leaks, so is it worth it to pull all the injectors and get them rebuilt? I have no idea what’s going on here. On another note, what’s the best manual for a 914 2.0? TIA Rob |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
If you have checked the compression and valve adjust and know that there are no top end noises (like a loose valve guide) I would start the car and let it idle, pulling one spark plug lead from the distributor cap at a time to localize the miss. THEN check the plug to see if it is sparking. If it is sparking, put a noid light in the injector lead to see if it is getting a signal. If it is switch injector leads. If not look at the ground leads at the back of the block. If you have misfire on diagonal cylinders, check the trigger points. That should be a good start
In the process of running down one thing after another, took the ‘74 2.0 out for a drive. Had a miss, so pulled the plugs. This car has spent a lot of the last 9 years sitting, so gas tank has been cleaned and fuel lines changed. #2 showed where a plug wire was barely attached which was quickly fixed, but the #3 plug was white. I mean really white. Like zero fuel lean. After looking at the connection to the injector, I saw the boot was ripped and the connection was pretty dirty, so I took i apart and sprayed electrical cleaner in it Drove it a couple miles, still had a miss, but when I pulled the #3 plug now it was black. Did I wake something up? Pulling the engine soon to fix oil leaks, so is it worth it to pull all the injectors and get them rebuilt? I have no idea what’s going on here. On another note, what’s the best manual for a 914 2.0? TIA Rob |
Lo-Fi Version | Time is now: 24th June 2024 - 07:30 AM |
