> Starting six when cold, Strange phenomena
gereed75
post Dec 29 2019, 05:49 PM
Car seems to start normally when warm
When cold (40 degrees or below) I can get car to start hesitantly after numerous pedal pumps to prime. It begins to run when motoring starter but as soon as I release key to run position the engine suddenly dies abruptly as if being switched off. I can eventually get it to run after very persistent motoring on the starter until it begins to clear and will finally run in the run position .
It just seems that the run/ignition circuit is significantly weaker in the run position than in the start position, like maybe the run contacts are high resistance or bad ground??
Are there two separate contacts in the ignition switch?? One for run and one for run/start??
Can the switch be opened and checked/cleaned??
Thanks.
gereed75
post Dec 30 2019, 02:04 PM
Thanks Tub, based on the idea they can be disassembled I’ll probably try to autopsy the orginal switch and if it goes bad replace it.
Let you all know what I find
- Lo-Fi Version Time is now: 5th February 2025 - 09:54 AM
