> 3.0 /6 in storage the case is filing with oil, and starting to leak on the floor.
Mark Henry
post Dec 26 2019, 12:51 PM
that's what I do!
So my '74 /6 conversion with the DWD sump tank is slowly leaking down into the engine sump. I have a leaking #6 rocker shaft that I'll have to R&R so I know my engine is full to at least to the exhaust rockers. I know it doesn't drain enough to do this if I drive at least weekly. I have a buddy who's well worn engine has hydrolocked a few times due to this.
I had to start and move the car, quite the smoke show.
Only automatic cure I've seen so far is a $300 valve from Rothsport. Or I could just install a ball valve and red tag my dash for just over $20.
I know it's a common 911 issue, do you other /6 owners have this issue and what do you do about it?
GeorgeRud
post Dec 30 2019, 05:06 PM
I’m always hesitant to place anything in the oil feed line as it’s function of providing a good oil supply to the pump is critical. But I have had the car look like I’m fogging the neighborhood for mosquitos after sitting for an extended time.
Mark Henry   3.0 /6 in storage the case is filing with oil   Dec 26 2019, 12:51 PM
brant   I just drain the oil each time I move the car from...   Dec 26 2019, 01:12 PM
Superhawk996   Only logical solution is to drive it daily. :D ...   Dec 26 2019, 01:25 PM
jd74914   A long time ago I worked on suspension project th...   Dec 26 2019, 03:22 PM
Superhawk996   You mean people didn't like the Citroen DS l...   Dec 26 2019, 03:59 PM
sixnotfour   your pretty handy , the Porsche part is $125,...   Dec 26 2019, 01:34 PM
porschetub   I haven't had this issue but mine is a baby ...   Dec 26 2019, 05:01 PM
76-914   https://www.amazon.com/Everflow-Supplies-21...C202...   Dec 26 2019, 08:13 PM
jd74914   https://www.amazon.com/Everflow-Supplies-21...C20...   Dec 26 2019, 09:49 PM
76-914   [quote name='76-914' post='2772532' date='De...   Dec 29 2019, 09:47 PM
thelogo   Almost Every war bird in thd chino planes of fame ...   Dec 27 2019, 01:35 AM
roblav1   Is yours leaking by through the pressure or scaven...   Dec 27 2019, 07:57 AM
Mark Henry   Is yours leaking by through the pressure or scave...   Dec 27 2019, 08:48 PM
Bills914-4   Just a thought , what about a electric pump just t...   Dec 27 2019, 08:38 AM
jc73-914   what about adding a manual shut off valve to the o...   Dec 27 2019, 11:48 AM
injunmort   had this problem on my nortons and indian. they si...   Dec 27 2019, 04:13 PM
gereed75   Would That improved racing check valve be a good a...   Dec 28 2019, 10:47 AM
sixnotfour   Would That improved racing check valve be a good ...   Dec 28 2019, 11:42 AM
gereed75   Yea after thinking about it more, the improved rac...   Dec 29 2019, 12:31 AM
gereed75   Yea after thinking about it more, the improved rac...   Dec 29 2019, 12:35 AM
ConeDodger   I did the valve, but I got it from Engine Builders...   Dec 29 2019, 01:14 AM
mb911   This whole thing scares me.. Wow can you imagine i...   Dec 29 2019, 07:16 AM
Krieger   Just a thought. During the off season. why don...   Dec 29 2019, 08:54 AM
gereed75   Wilhoit says that the flapper is held closed by a ...   Dec 29 2019, 09:58 AM
GeorgeRud   I’m always hesitant to place anything in the oil...   Dec 30 2019, 05:06 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 10:02 PM
