Porsche 914 1.8 L doesn't want to start with petrol? Wrong distributor without negative pressure to blame? |
Leon.paradise |
Dec 30 2019, 01:03 PM
Newbie Group: Members Posts: 10 Joined: 30-December 19 From: Munich Member No.: 23,780 Region Association: None |
Hello I am from Germany and hope that someone from you can finally help me. Unfortunately I have not found anyone who could help me. This year I bought an American Porsche 914, 1.8 L, with 76 HP, which is original and has not been moved since 1997 and has never driven in Europe. It is a project the car has an L-Jetronic injection system. I have already exchanged a lot to start the engine with petrol, unfortunately without success until now. It wanted to ignite with Spray Gas, but not with gasoline. The following components were rinsed out or tried out: new tank, power pump, lines, filters, injection nozzles, ultrasound cleaned, other control unit, wiring harness measured perfectly, new spark plugs. Spark is there. Air mass meter supposedly OK. I have the 7 pin connector. But the car is not running. I have been looking for the mistake since May. In Germany almost no L-Jetronic only drive D-Tronic or carburettors. Question to you, you can also operate the Porsche L-Jetronic with 009 distributor without vacuum socket. Or does he necessarily need an ignition distributor with a vacuum socket. Now I have the distributor (0231 178 009). Did you find out that it is unsuitable? Since it works on carburetors and not on L-jetronic? I have now bought a (022905205S) because it was originally installed ex works? Ask for help and your answers. Greetings Leon
timothy_nd28 |
Dec 31 2019, 11:42 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
George is absolutely correct, a warped AFM flap will keep the fuel pump on. Even a small backfire can cause that flap to warp. Leon, you should manually push open the flap inside the air flow meter, and see if it springs back closed. Also, verify the flap moves without hanging up.
I can help walk you through diagnosing the issue. Do yo have a voltmeter? You will also need to figure out how to add pictures |
Lo-Fi Version | Time is now: 27th December 2024 - 02:43 PM |
