> How To: Swivel foot valve adjusters on a 74-76 2.0L?
JeffBowlsby
post Jan 10 2007, 06:10 PM
914 Wiring Harnesses
So those in the know...how is this conversion done? I don't now the specifics so please tell me. I understand that the stock 74-76 2.0L cars use a larger-diameter adjuster and cannot accept the swivel foot adjusters because they are smaller. The needed parts as I understand it are:
* Rocker arms/shaft assemblies from a 1.7L engine
* Swivel feet valve adjusters (10mm?)
* Shims
Is all the above correct?
What shims do I need and where are they installed?
Is there further machining to do to the rocker arms?
All details please...Thanks in advance (IMG:style_emoticons/default/biggrin.gif)
bbrock
post Dec 23 2019, 05:15 PM
Here's a machining service and source for swivel feet.
https://www.thesamba.com/vw/classifieds/det....php?id=2060099
Or here is the link to direct ordering the adjusters from the manufacturer.
http://www.tp-technologie.de/produkte%20ve...ellsch%20en.htm
Not Genuine Porsche but have gotten good reviews. I think @nditiz1 installed them. If so, maybe we can get an update.
nditiz1
post Jan 1 2020, 05:33 PM
They worked out great. I saw no issues while using them. The machining was also done well. I had the same guy machine the stock pushrods so as to get the correct rocker geometry.
Jeff Bowlsby   How To: Swivel foot valve adjusters on a 74-76 2.0L?   Jan 10 2007, 06:10 PM
Twystd1   Yup... You have the right parts. Now you need to ...   Jan 10 2007, 06:32 PM
Jeff Bowlsby   Clayton...you are golden...PM me your address and ...   Jan 10 2007, 08:19 PM
Twystd1   PMing you now... C   Jan 10 2007, 08:30 PM
gregrobbins   Here's a photo I copied from somewhere.   Jan 10 2007, 08:47 PM
Twystd1   Thats the exact photo I was searching for..... Th...   Jan 10 2007, 08:52 PM
Aaron Cox   Thats the exact photo I was searching for..... T...   Jan 10 2007, 11:53 PM
CHAFF   Hi Aaron, Let me get this straight....if you grind...   Feb 26 2007, 08:35 PM
morph   where did you get the spacers to replace the sprin...   Jan 11 2007, 12:11 AM
swood   where did you get the spacers to replace the spri...   Jan 11 2007, 12:28 AM
Twystd1   Heee..Heeee Aaron said his engine sees 6000 rpms....   Jan 11 2007, 12:19 AM
Twystd1   The Jakester and aircooled.net sells em also.. C   Jan 11 2007, 12:40 AM
Aaron Cox   i got mine off ebay and clearanced em to .004...   Jan 11 2007, 01:28 AM
Mike914   i got mine off ebay and clearanced em to .004...   Feb 26 2007, 08:59 PM
CHAFF   Could you not just grind the face of the swivel fo...   Feb 26 2007, 09:19 PM
Dave_Darling   Could you not just grind the face of the swivel f...   Feb 26 2007, 09:33 PM
CHAFF   Man, there sure seems to be alot of misleading inf...   Feb 26 2007, 09:40 PM
jd74914   Man, there sure seems to be alot of misleading in...   Feb 26 2007, 09:46 PM
CHAFF   Ok here is my deal. I understand that this will r...   Feb 26 2007, 10:19 PM
Aaron Cox   Ok here is my deal. I understand that this will ...   Feb 26 2007, 10:20 PM
Dave_Darling   But here is the question no one wants to answer.....   Feb 27 2007, 01:40 AM
Aaron Cox   You need to clearance 60 tho off the rocker face. ...   Feb 26 2007, 10:10 PM
CHAFF   Thanks Aaron, that answers it. You need to clear...   Feb 26 2007, 10:22 PM
Jake Raby   I have a 9,000 word step by step valve train geome...   Feb 27 2007, 12:23 AM
914werke   I thought Id update the descriptive image. :)   Dec 22 2019, 07:53 PM
maf914   Rich, Nice clarification to the earlier posted pho...   Dec 23 2019, 06:42 AM
914Sixer   10mm swivel foot German adjusters are now availabl...   Dec 23 2019, 11:35 AM
914werke   good to know, source?   Dec 23 2019, 03:17 PM
bbrock   Here's a machining service and source for swiv...   Dec 23 2019, 05:15 PM
nditiz1   They worked out great. I saw no issues while usin...   Jan 1 2020, 05:33 PM
Mark Henry   Yes you have to machine and countersink the rocker...   Jan 3 2020, 08:51 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 01:42 PM
