> Can't find 4th gear, I no i put it in there
Bruce Edge
post Jan 2 2020, 07:34 PM
Old School 914
I can go in to all gears except 4th gear. Side shift, rebuilt, bench tested with all gears working properly. all new bushings from gear shift leaver back to side shift. after going thru the general set up for long shift rod(tube) gear leaver pinch bolt ect. Here is what i have found the problem to be so far(I think).
When going in to 4th gear the long shift tube rolls to the highest point where it goes through the motor mount bar. Well, the tube hits the top of the hole in the bar not letting the lever in the transmission come down far enough. All new motor mounts were install.
So, do I raise the mount bar on the left side to see if that helps, hone out the hole in the mount some. I know all this rambling may not make sense, but hoping someone that had the same experience would pick up on what I was trying to say.
Any pointers is greatly appreciated.
Thanks,
Bruce
iankarr
post Jan 3 2020, 12:39 PM
Great! Glad you got it sorted.
- Lo-Fi Version Time is now: 27th December 2024 - 07:49 PM
