Drilling Spot Welds, What do you use? |
obscurity |
Apr 15 2010, 08:09 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I have been drilling spot welds as I work on my car and it occured to me that there may be a better way (or maybe I am being to picky). I am curious what everyone else uses.
I have been using a spot weld cutter. It looks like a short drill bit with a pilot point and little cutters along the edge. It will cut through the top layer or steel but not the back layer (usually). They will cut about 10 welds before being hoplessly dull. When I was buying them at $5/bit it was fine but that company went out of business and the ones I find now are $25/bit. Are these the right tools to use or should I be just using a drill bit allthe way through the weld. Any help or tool suggestions would be appreciated. (IMG:style_emoticons/default/smile.gif) Thanks, John W. |
bkrantz |
Jan 3 2020, 09:30 PM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have noticed that with the Blair cutter, the 3 bits that came in the kit seemed to dull quickly, but the first replacement bit has stayed sharp after drilling many more spot welds.
Lo-Fi Version | Time is now: 27th December 2024 - 03:55 PM |
