Vented Heads / Breather Box, One Does - The Other Doesn't!!! |
d7n7master |
Dec 7 2004, 03:25 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi All,
I tried a "search" but came up with nothin'... I have a 2.0 that needs a rebuild. I have a fresh longblock ready for me to transfer all the accessories now that their re-painted. As I was fitting the engine tin I noticed that my (old) engine has the heads vented. The vent hoses were attached to the air cleaner. The (new) engine has NO VENT PIPES!!! Now what? Should I just add a breather to the oil filler??? Or...? (IMG:style_emoticons/default/unsure.gif) Thanks, Gary |
URY914 |
Dec 8 2004, 08:43 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
QUOTE(SLITS @ Dec 7 2004, 08:20 PM) QUOTE(bperry @ Dec 7 2004, 09:04 PM) Any suggestions on fittings? Can you just tap the hole and use a threaded brass fitting directly? --- bill Standard pipe thread hose barb....I would think about 3/8" i.d. (guessing). I would try to match the factory i.d. If doing this while the head is on the engine, I would use a shop vac to suck up the metal as you drill and tap. You can also use heavy grease on the tap to trap the cuttings to avoid metal intrusion into the engine. Also take the v/c off and use the shop vac inside to suck the cutting out from the inside. I drilled a hole and epoxied (JB Weld) a barb onto my v/c. No leaks and simple. but be careful of the location in relation to the bale wire. Mine are on the ends toward the top. P |
Lo-Fi Version | Time is now: 26th June 2024 - 06:39 AM |
