Wipers don’t work |
Wipers don’t work |
malcolm2 |
Jan 18 2020, 10:18 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
2nd time happening. I move the wiper lever and no movement.
Last time I pulled the steering wheel, unplugged all 3 connectors, re connected and everything worked. I figured the wiper plug came lose, so I added some duct tape. Connector to connector and they wiped. Damn wipers stopped again tonight. What am i missing? |
Mark Henry |
Jan 19 2020, 09:45 AM
Spin the fuse in the holder, if it works replace the fuse, but what you really need to do is disconnect the whole fuse block and soak it in vinegar to clean it. Then replace and use all new fuses.
malcolm2 |
Jan 19 2020, 12:49 PM
Spin the fuse in the holder, if it works replace the fuse, but what you really need to do is disconnect the whole fuse block and soak it in vinegar to clean it. Then replace and use all new fuses. I have the upgraded fuse box with the blade type fuses. Installed in 2012. I just pulled the wheel, switches, etc.... unplugged and re-plugged. Turn the key on, hit the wiper lever and the wipers worked. Guess I will look for that switch. part #s welcomed (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 05:54 PM |
