Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
Ive been running a "square" set up for years. 15x7 with 205/50/15 Hoosiers.
I'm now contemplating running wider rears then fronts and started to ask myself why? At the HSR races all the 914 guys are staggered. It looks like the PCA guys stagger too. Whats the performance advantage here? Is it handling? Something to do with getting hard on the brakes? Putting the power down? Fitment on the front suspension? Teach me something.... (IMG:style_emoticons/default/beerchug.gif) |
Jetsetsurfshop |
Tire temps will be priority one at the track. The guys I race with have the tool that has memory built in. Should be pretty easy. They are always pretty stressed about the corvette they run. I try to stay clear when that car acts up but if I ask for help they will be glad to do it.
It looks like I might be the only one in my run group again so I can use then weekend to tune tire pressures. I just hope the camber isn't off. I feel that I have that close from what everyone else uses. I could alter my front easy but I don't want to mess with the rears until I can get on a alignment rack. Plus, I don't want to do anything with my alignment at the track. I'm sure I'd mess it up or miss races while figuring it out. About the slight push I have. With a full take of gas I go where the fuel goes. (Only fill it up for endurance races) Its kinda funny at first but once you burn down to 1/2 tank it gets to be fun. I might even be looking for some sort of excuse for my sub par racing skills. I found this chart on another forum. I downloaded it but cant find the forum again. I have no idea if this sheet is legit or not. If it is there are thing I can do on this sheet like soften my front sway-bar. Is all this stuff known racing knowledge? Attached thumbnail(s) ![]() |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 918 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
The chart is generally in line with my understanding, though a bit more detailed than the things I usually think about. Swaybars and tire pressures are the easiest things to change at the track, so I'd start there. Tire temps may be telling too. Lots of variables there depending on what the temps are.
For swaybar adjustment, to fix a push I'd either loosen the front sway (move the adjuster closer to the end of the arm) by one position if your setup had the multi-hole adjustment style, or by 1" if you have the slider style adjustment. Or stiffen the rear bar by a similar amount. Whichever you choose, just make sure you do both sides by the same amount (IMG:style_emoticons/default/smile.gif) |
Jetsetsurfshop |
The chart is generally in line with my understanding, though a bit more detailed than the things I usually think about. Swaybars and tire pressures are the easiest things to change at the track, so I'd start there. Tire temps may be telling too. Lots of variables there depending on what the temps are. For swaybar adjustment, to fix a push I'd either loosen the front sway (move the adjuster closer to the end of the arm) by one position if your setup had the multi-hole adjustment style, or by 1" if you have the slider style adjustment. Or stiffen the rear bar by a similar amount. Whichever you choose, just make sure you do both sides by the same amount (IMG:style_emoticons/default/smile.gif) This is what i was thinking. I'll start with tire temps and pressures first. See where I'm at. We have a friend that used to crew for an IMSA team that always comes with us. I can lean on him for help. I'll just have to buy dinner. (IMG:style_emoticons/default/chowtime.gif) My front sway bar would be easy to adjust in-between sessions. Should have plenty of time to get that done if needed. Thanks!! (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:18 AM |
