Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Good morning gentlemen, have a question on moving a tuna can from one 2.0l case to another. It appears that it all should just transfer over if it is a good quality assembly, right? The 2.0L turbo engine I removed has one, the 2.0L engine I installed does not.
And yes, I will make sure there is no actual tuna in the can first. Thanks! |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Dont overtighten it when you put it back!
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Dont overtighten it when you put it back! IMHO every 914 or any T4 owner should have an inch pound torque wrench. The oil sump plate is 9 ft/lbs which is 108 inch/lbs...not a pound more. I also work on 996/7 engines, lots of M6 bolts in alunimum, 7.5 Ft/lbs, no inch pound torque wrench and you'll be heli-coiling a lot of holes. On 914 every engine I build I helicoil the taco plate bolt holes. I've had to replace a few cases due to over torquing the sump plate resulting in a broken bolt boss, including one on a customers brand new performance engine. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:29 PM |
