Microsquirt build, my attempt... And while I am in there..., Remote oil filter / cooler and fuel pump front relocation |
Montreal914 |
Dec 22 2019, 01:53 PM
Senior Member Group: Members Posts: 1,699 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
After reading and reading some more, I finally decided a few months ago to challenge myself with a Microsquirt conversion. Many members here were very inspirational. (IMG:style_emoticons/default/smilie_pokal.gif) I want to thank the ones who have shared their builds and issues as they are very helpful. I hope my build can contribute to others and add to this wealth of information. I'm also aware that I might run into issues but that is part of the process.
First, a little background. A few years back I rebuilt my 2.0 due to a spun rod bearing on my last run of my first DE event with POC at Streets of Willows. (IMG:style_emoticons/default/driving.gif) While this was an unpleasant outcome, the day still remains a fantastic moment with my 914. (IMG:style_emoticons/default/smile.gif) I did the rebuild myself with all of the valuable information here. (IMG:style_emoticons/default/first.gif) I like to think that I did things right and the outcome is a fun 2056 with mild cam, D-Jet oblige, that I have enjoyed commuting with for many years and took along the coast all the way to Monterey four times, two of which were to attend the amazing Rennsport Reunion V and VI. (IMG:style_emoticons/default/pray.gif) One of the reasons I want to upgrade to a modern FI system is to be able to better tune the engine which is limited on the D-Jet, especially when engine displacement is increased as we know. This is the first step in my ultimate build which would be a 78x96 stroker engine. But that will be later. (IMG:style_emoticons/default/drooley.gif) So here we go! I bought my Microsquirt and crank trigger sensor sensor setup from Mario at the Dubshop. I like the way the trigger is engineered and it allows the installation of remote oil plumbing (full-er flow setup). Being on a very tight budget (I know this doesn't rimes with 914 anymore) I bought all my new individual components from ebay with matching pigtail connectors to build my own harness. VW waste spark coil pack GM 1 bar MAP sensor Hyundai (and others) TPS BMW ICV BMW air cooled motorcycle CHT sensor (used). Same M10 thread as the D-Jet CHT. I will be reusing: Stock green injectors, with additional resistors Stock IAT sensor I also bought new connectors and crimp terminals and boots for all reused stock components. To begin the build, I elected to prepare a development harness with extra wire length and build a bread board setup. This will allow me to make sure that all components are functioning. Once the engine is running, I will rebuild the harness with the proper wire length and sleeves to ensure a clean and reliable installation. Enough writing... On with what people want! Pictures (IMG:style_emoticons/default/biggrin.gif) Bread Board setup: 1 Bar GM MAP Sensor: Resistance pack for low impedance green stock injectors. The resistances are not needed if you use modern high impedance injectors. Used BMW Motorcycle Cylinder Head Temp sensor with M10 thread which will screw in the stock 2.0 head CHT location. Throttle position switch compatible with the stock 914 throttle body with its 8mm D shape shaft. Stock intake air temp sensor with new crimp and connector: |
Montreal914 |
Jan 19 2020, 08:27 PM
A little more work done this weekend. (IMG:style_emoticons/default/smash.gif)
First, Friday ( I get every second Friday off (IMG:style_emoticons/default/pray.gif) ) I went to EMW and got my oil pump blocked off. They pressed a slug in the hole. It felt like it was protruding a little over the pump diameter so I gently filed it down and checked the diameter once done. It is now ready for the re-installation. I'm hoping to get a cast iron full flow pump cover with pressure relief from Gene Berg maybe tomorrow if they are open. Then I fabricated a block off plate for the oil filter mount that I am removing. I used a 1/4" aluminum plate and my trusted hack saw, vise, file and HF drill... (IMG:style_emoticons/default/smash.gif) While I was at it making blanks, I also did one for the plenum as I will not be using the stock Cold Start Valve (CSV) anymore. Next steps ahead, oil pump and cover installation, and Dub Shop crank trigger setup. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beer3.gif) |
JamesM |
Jan 21 2020, 09:44 AM
Senior Member Group: Members Posts: 1,991 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
While I was at it making blanks, I also did one for the plenum as I will not be using the stock Cold Start Valve (CSV) anymore. Not sure what your your plan is for the idle valve pluming, but that plastic block under the cold start injector is the port for the stock aux air regulator. May want to leave it and put your block off plate on top of it. |
Montreal914 |
Jan 26 2020, 01:17 AM
While I was at it making blanks, I also did one for the plenum as I will not be using the stock Cold Start Valve (CSV) anymore. Not sure what your your plan is for the idle valve pluming, but that plastic block under the cold start injector is the port for the stock aux air regulator. May want to leave it and put your block off plate on top of it. Thank you for pointing it out (IMG:style_emoticons/default/beerchug.gif) After reviewing the various ports on the plenum, the only one available for a 13mm ID hose is the plastic one by the stock CSV injector as you mentioned. Therefore, if I'm going with this hose setup on my BMW valve, I should use the plastic port and place the block off plate on top. I might revisit my plans to connect the BMW idle vale to the 10mm port that was used for the stock decel valve that will be removed. Otherwise I will need to plug that port. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 22nd November 2024 - 12:52 PM |
