> Powered washer fluid assembly
swood
post Nov 29 2009, 07:40 PM
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics.
First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself.
Can I mount my pump in this area?
I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet.
davep
post Jan 29 2020, 09:46 PM
914 Historian
So I designed a disc that was 3D printed to fit the cap and provide the venting for my kit, and the mount for a momentary switch to replace the water valve. No need to replace the wiper switch assembly.
swood   Powered washer fluid assembly   Nov 29 2009, 07:40 PM
swood   Lastly, the steering column switch. Again looking...   Nov 29 2009, 07:41 PM
bobhasissues   I'm looking at the first picture of your resev...   Nov 29 2009, 08:41 PM
barefoot   Lastly, the steering column switch. Again lookin...   Jan 26 2020, 09:42 PM
r_towle   924 uses the correct switch for the column. Pump v...   Nov 29 2009, 07:45 PM
flipb   Has anyone ever stuck with the stock setup but add...   Nov 29 2009, 08:54 PM
Kirmizi   Stevo, I did this modification on my '75. I mo...   Nov 29 2009, 09:01 PM
SirAndy   I mounted the pump beneath the fluid reservoir (a...   Nov 30 2009, 01:13 PM
kconway   My car has this mod. The pump is mounted right we...   Nov 29 2009, 09:11 PM
516randy   I believe the rare factory install of the washer p...   Nov 29 2009, 09:13 PM
swood   I was thinking that if the pump went under the tan...   Nov 29 2009, 09:30 PM
davep   http://www.914world.com/bbs2/index.php?showtopic=6...   Nov 30 2009, 12:43 PM
zonedoubt   I recommend using some inline check valves at each...   Nov 30 2009, 03:42 PM
swood   Ok, i see my first error. There won't be any ...   Nov 30 2009, 10:12 PM
swood   So do I need to locate the wire that gets connecte...   Nov 30 2009, 11:01 PM
Spoke   I'm not familiar with the pink/black wire. May...   Dec 1 2009, 10:47 AM
davep   I'm not familiar with the pink/black wire. Ma...   Dec 1 2009, 01:52 PM
detoxcowboy   I'm not familiar with the pink/black wire. M...   Dec 1 2009, 02:59 PM
detoxcowboy   I suggest you read the pelican parts tech article ...   Dec 1 2009, 11:14 AM
McMark   Here's the stock 914/6 washer pump mounting ho...   Dec 1 2009, 05:49 PM
FlacaProductions   Hi All - I'm really sorry to dredge this up ag...   Jan 26 2020, 12:48 PM
914Sixer   You will have to match the wire location of the af...   Jan 26 2020, 03:33 PM
FlacaProductions   Yep. I agree. I think I finally have this correc...   Jan 26 2020, 03:58 PM
FlacaProductions   Thanks @barefoot - I have that switch as well bu...   Jan 26 2020, 09:46 PM
RickS   Wow, rather than dealing with mounting the stalk s...   Jan 26 2020, 10:07 PM
cary   http://www.914world.com/bbs2/index.php?showtopic=3...   Jan 26 2020, 10:27 PM
FlacaProductions   I've read all of the threads on this and done ...   Jan 27 2020, 09:30 AM
ctc911ctc   I just changed the wiper selector in my '74 2....   Jan 28 2020, 01:55 PM
ctc911ctc   OK, I think I guessed incorrectly.....however, ...   Jan 29 2020, 05:08 PM
FlacaProductions   that should be correctly plumbed - the one with th...   Jan 29 2020, 06:53 PM
ctc911ctc   that should be correctly plumbed - the one with t...   Jan 29 2020, 08:51 PM
SirAndy   is the tank vented so a vacuum isn't created? ...   Jan 29 2020, 09:31 PM
ctc911ctc   Yes, I have the filler cap off - biggest hole I co...   Jan 30 2020, 07:19 AM
FlacaProductions   not sure it's exactly gravity fed but i've...   Jan 29 2020, 08:58 PM
davep   So I designed a disc that was 3D printed to fit th...   Jan 29 2020, 09:46 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 09:36 AM
